Author Topic: Auditing a list of numerical string atoms  (Read 5438 times)
Re: Auditing a list of numerical string atoms
« Reply #15 on: April 01, 2017, 08:50:26 AM »
Nice job Lee  8)
Thanks Alan - you too  :-)
roy_043
  • BricsCAD 18
« Reply #16 on: April 01, 2017, 11:14:22 AM »
Another:
  1. (defun AuditList (lst / doneLst dubLst i invLst misLst)
  2.   (foreach itm lst
  3.     (cond
  4.       ((wcmatch itm "*[~0-9]*")
  5.         (if (not (member itm invLst)) (setq invLst (cons itm invLst)))
  6.       )
  7.       ((member (setq itm (atoi itm)) doneLst)
  8.         (if (not (member itm dubLst)) (setq dubLst (cons itm dubLst)))
  9.       )
  10.       (T
  11.         (setq doneLst (cons itm doneLst))
  12.       )
  13.     )
  14.   )
  15.   (repeat (- (apply 'max doneLst) (setq i (apply 'min doneLst)) 1)
  16.     (if (not (member (setq i (1+ i)) doneLst))
  17.       (setq misLst (cons i misLst))
  18.     )
  19.   )
  20.   (list
  21.     invLst ; Invalid.
  22.     dubLst ; Duplicate.
  23.     misLst ; Missing.
  24.   )
  25. )
« Last Edit: April 01, 2017, 11:23:53 AM by roy_043 »
Grrr1337
« Reply #17 on: April 01, 2017, 02:01:55 PM »
  1. (defun qs ( l )
  2.     (   (lambda ( f ) (if l (f (car l) (cdr l))))
  3.         (lambda ( x l / a b )
  4.             (foreach y l
  5.                 (if (< y x)
  6.                     (setq a (cons y a))
  7.                     (setq b (cons y b))
  8.                 )
  9.             )
  10.             (append (qs a) (cons x (qs b)))
  11.         )
  12.     )
  13. )
The idea of this is to function as acad_strlsort ?
Just asking because the foreach and the recursion part confuses me.  :thinking:
(apply ''((a b c)(a b c))
vevo.bg
« Reply #18 on: April 01, 2017, 02:16:34 PM »
  1. (defun qs ( l )
  4.             (foreach y l
  5.                 (if (< y x)
  8.                 )
  9.             )
  11.         )
  12.     )
  13. )
It's an implementation of the Quicksort algorithm (i.e. a Vanilla equivalent to vl-sort), with the first item of the list selected as the pivot.
The function may be easily modified to accept an arbitrary comparison function, e.g.:
  1. (defun qs ( l c )
  2.     (   (lambda ( f ) (if l (f c (car l) (cdr l))))
  3.         (lambda ( c x l / a b )
  4.             (foreach y l
  5.                 (if (apply c (list y x))
  8.                 )
  9.             )
  10.             (append (qs a c) (cons x (qs b c)))
  11.         )
  12.     )
  13. )
  1. _$ (qs '(5 6 2 4 1 7 3 8) '<)
  2. (1 2 3 4 5 6 7 8)
  3. _$ (qs '(5 6 2 4 1 7 3 8) '>)
  4. (8 7 6 5 4 3 2 1)
Grrr1337
« Reply #19 on: April 01, 2017, 02:32:33 PM »
Very impressive function, especially when you must deal only with vanilla lisp!
Would be very handy for David, if he defuns it as vl-sort. :)
vevo.bg
« Reply #20 on: April 01, 2017, 02:37:50 PM »
Thanks - though of course, Quicksort is only one possible sorting algorithm - you might be interested in this thread:-)
Grrr1337
« Reply #21 on: April 01, 2017, 03:16:03 PM »
Thanks Lee, I've seen that thread before - but nothing similair like the function you wrote here.
Although the algorithm might be the same, for me it looks completely different (atleast comparing to the Gile's quicksort).
vevo.bg
David Bethel
« Reply #22 on: April 01, 2017, 04:40:55 PM »
What I really like about this kind of problems is that it makes one think :idiot2:
Without a sorting or recursive
Code - Text: [Select]
  1. (defun db:anum (nl / il minn maxn i ml dl bl gl fl)
  2. ;;;GOOD AND BAD LISTS
  3.   (foreach a nl
  4.      (if (wcmatch a "*[~0-9]*")
  5.          (setq bl (cons a bl))
  6.          (setq gl (cons a gl))))
  7.
  8.   (setq il (mapcar 'atoi gl)
  9.       minn (apply 'min il)
  10.       maxn (apply 'max il)
  11.          i minn)
  12.
  13.   (repeat (1+ (- maxn minn))
  14.       (setq fl (cons (list i 0) fl))
  15.       (setq i (1+ i)))
  16.
  17.   (foreach n il
  18.     (if (assoc n fl)
  19.         (setq fl (subst (list n (1+ (cadr (assoc n fl))))
  20.                         (assoc n fl) fl))))
  21.
  22.   (foreach n fl
  23.     (cond ((= 1 (cadr n)))
  24.           ((= 0 (cadr n)) (setq ml (cons (car n) ml)))
  25.           ((< 1 (cadr n)) (setq dl (cons (car n) dl)))))
  26.
  27.   (princ "\nFull List : \t")(prin1 fl)
  28.   (princ "\nDuplicate : \t")(prin1 dl)
  29.   (princ "\n  Missing : \t")(prin1 ml)
  30.   (princ "\n      Bad : \t")(prin1 bl)
  31.   (prin1))
  32.
I'll have to noddle on the rest of variations.  Thanks to all !  -David
R12 Dos - A2K
