Author Topic: Auditing a list of numerical string atoms  (Read 5236 times)
David Bethel
« on: March 31, 2017, 09:01:54 AM »
Good morning,
Dealing with items number bubble identifiers
I'm looking to audit a list of string values that :
  • Should always be a string containing a positve INTeger
  • Can have duplicate atoms in the list
  • The order does not matter
(setq nl '("12" "13" "14" "1" "3" "4" "6" "7" "2" "8" "9" "10" "16" "17" "18" "22" "24" "26" "27" "20" "21" "19" "23" "15" "29" "34" "35" "36" "37" "29" "31" "32" "33" "30" "38" "39" "40" "41" "42" "43" "49" "44" "45" "46" "47" "48" "50" "50" "48" "5" "25" "28"))
I am looking to report :
  •   Any if any of the atoms are strings that are not a positive INTeger
  •   Any missing numbers in the sequence from the list's minimum value to the list's maximum value
  •   Any number that is duplicated in the list ( the qty of duplicates is not important )
  •   Any other info you can think of that would be helpful in finding errors or omissions
*** ( In Plain AutoLisp )
So far :
  1. (defun anum (nl / il minn maxn i ml dl)
  2.
  3. (setq il (mapcar 'atoi nl)
  4.     minn (apply 'min il)
  5.     maxn (apply 'max il)
  6.        i minn)
  7.
  8. (while (<= i maxn)
  9.        (cond ((not (member i il))
  10.               (setq ml (cons i ml)))
  11.              ((and (member i (cdr (member i il)))
  12.                    (not (member i dl)))
  13.               (setq dl (cons i dl))))
  14.        (setq i (1+ i)))
  15.
  16. (princ "\nDuplicates : ")
  17. (prin1 dl)
  18. (princ "\nMissing : ")
  19. (prin1 ml)
  20.
(member (member))  is a horrible test
I don't think (atoi) will return an error that can be captured
 Any suggestions to make this more robust ?
TIA  -David
« Last Edit: March 31, 2017, 09:08:40 AM by David Bethel »
R12 Dos - A2K
Grrr1337
Re: Auditing a list of numerical string atoms
« Reply #1 on: March 31, 2017, 09:51:03 AM »
Hi David,
For the first report task:
  1. _$ (mapcar
  2.   '(lambda (x / n) (setq n (read x)) (or (minusp n) (eq 'REAL (type n))))
  3.   '("1.1" "2" "3" "4" "5.6" "-6")
  4. )
  5. (T nil nil nil T T)
  6. _$
For the second report task:
Use these:
  1. (defun FindDifference ( nl / n L )
  2.   (setq n 0)
  3.   (repeat (fix (apply 'max (mapcar 'read nl)))
  4.     (setq L (cons (itoa (setq n (1+ n))) L))
  5.   )
  6.   ; Start comparing:
  7.   (LM:ListDifference
  8.     (setq L (acad_strlsort L))
  9.     (setq nl (acad_strlsort nl))
  10.   )
  11. ); defun FindDifference
  12.
  13. ;; List Duplicates  -  Lee Mac
  14. ;; Returns a list of items appearing more than once in a supplied list
  15.
  16. (defun LM:ListDupes ( l )
  17.   (if l
  18.     (if (member (car l) (cdr l))
  19.       (cons (car l) (LM:ListDupes (vl-remove (car l) (cdr l))))
  20.       (LM:ListDupes (vl-remove (car l) (cdr l)))
  21.     )
  22.   )
  23. )
  24.
  25. ;;-------------------=={ List Difference }==------------------;;
  26. ;;                                                            ;;
  27. ;;  Returns items appearing exclusively in one list but not   ;;
  28. ;;  another, i.e. the relative complement: l1 \ l2            ;;
  29. ;;------------------------------------------------------------;;
  30. ;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
  31. ;;------------------------------------------------------------;;
  32. ;;  Arguments:                                                ;;
  33. ;;  l1,l2 - lists for which to return the difference          ;;
  34. ;;------------------------------------------------------------;;
  35. ;;  Returns:  List of items appearing exclusively in list l1  ;;
  36. ;;------------------------------------------------------------;;
  37.
  38. (defun LM:ListDifference ( l1 l2 )
  39.   (if l1
  40.     (if (member (car l1) l2)
  41.       (LM:ListDifference (cdr l1) l2)
  42.       (cons (car l1) (LM:ListDifference (cdr l1) l2))
  43.     )
  44.   )
  45. )
Result:
  1. (setq nl
  2.   '("12" "13" "14" "1" "3" "4" "6" "7" "2" "8" "9" "10"
  3.     "16" "17" "18" "22" "24" "26" "27" "20" "21" "19" "23"
  4.     "15" "29" "34" "35" "36" "37" "29" "31" "32" "33" "30"
  5.     "38" "39" "40" "41" "42" "43" "49" "44" "45" "46" "47"
  6.     "48" "50" "50" "48" "5" "25" "28"
  7.   )
  8. )
  9. _$ (FindDifference nl)
  10. ("11") ; this means that eleven is missing
  11. _$ (LM:ListDupes nl)
  12. ("29" "48" "50") ; these occur more than once
  13. _$
(apply ''((a b c)(a b c))
vevo.bg
David Bethel
« Reply #2 on: March 31, 2017, 10:13:56 AM »
Thanks Grrr
I'll take  look, but I don't have access to any vl-  type calls, only plain autolisp.
-David
R12 Dos - A2K
Grrr1337
« Reply #3 on: March 31, 2017, 10:46:30 AM »
Oops, sorry David!
I did not notice that LM:ListDupes uses (vl-remove) - my other thought is to create unique item counter, which should do something like:
'("A" "B" "C" "D" "D" "A") -> '(("A" . 2) ("B" . 1) ("C" . 1) ("D" . 2))And by that way the duplicates can be found.
vevo.bg
roy_043
  • BricsCAD 18
« Reply #4 on: March 31, 2017, 10:51:30 AM »
To check for 'pos. int string':
(wcmatch str "~*[~0-9]*")
You should do this before using atoi as that function will always return an integer.
« Reply #5 on: March 31, 2017, 12:15:03 PM »
A different approach, return numbers though
(defun anum (lst / lastitm neg missing)
  (foreach itm (vl-sort (mapcar 'atoi lst) '>)
      ((minusp itm) (setq neg (cons itm neg)))
      ((null lastitm) (setq lastitm itm))
      (t (if (/= (1- lastitm) itm)
           (progn (while (/= (1- lastitm) itm)
             (setq missing (cons (1- lastitm) missing)
                 lastitm (1- lastitm)))(setq lastitm (1- lastitm)))
           (setq lastitm itm)
  (list neg missing)
David Bethel
« Reply #6 on: March 31, 2017, 01:16:02 PM »
That is a bit different.  I'll have to dig into it.  I do roll your own sort routines so that's not a problem
Thanks All !  -David
R12 Dos - A2K
« Reply #7 on: March 31, 2017, 01:29:44 PM »
This avoids the (member (member)), but it's not particularly pretty:
  1. (defun checklist ( lst / dun dup int inv mim mis mxm )
  2.     (foreach itm lst
  3.         (if (wcmatch itm "*[~0-9]*")
  4.             (or (member itm inv) (setq inv (cons itm inv)))
  5.             (setq int (cons itm int))
  6.         )
  7.     )
  8.     (setq int (mapcar 'atoi int)
  9.           mxm (apply  'max  int)
  10.           mim (apply  'min  int)
  11.     )
  12.     (foreach itm int
  13.         (and (<= mim mxm)
  14.              (or (member mxm int)
  15.                  (setq mis (cons (itoa mxm) mis))
  16.              )
  17.              (setq mxm (1- mxm))
  18.         )
  19.         (or (and (member itm dun)
  20.                  (or (member (itoa itm) dup)
  21.                      (setq dup (cons (itoa itm) dup))
  22.                  )
  23.             )
  24.             (setq dun (cons itm dun))
  25.         )
  26.     )
  27.     (while (<= mim mxm)
  28.         (or (member mxm int)
  29.             (setq mis (cons (itoa mxm) mis))
  30.         )
  31.         (setq mxm (1- mxm))
  32.     )
  33.     (princ "\nInvalid items: ")
  34.     (prin1 inv)
  35.     (princ "\nMissing items: ")
  36.     (prin1 mis)
  37.     (princ "\nDuplicate items: ")
  38.     (prin1 dup)
  39.     (princ)
  40. )
David Bethel
« Reply #8 on: March 31, 2017, 01:54:35 PM »
I was heading towards adding a bad list also.
The list is normally less than 100 atoms so I guess (member) testing is not all that bad.
It does seem that there should be a simple solution.  But here accuracy is going to rule.  Thanks!  _David
R12 Dos - A2K
« Reply #9 on: March 31, 2017, 03:10:13 PM »
You don't need to worry about performance then .. go for your own readability :)
« Reply #10 on: March 31, 2017, 04:03:01 PM »
Had a few minutes to make another run at this one with Gile's Sort
  1. ;;;=============================================================
  2. ;;;Gile's Insert Sort
  3. ;;;=============================================================
  4. (defun G:InsertSort (lst / insert)
  5.
  6.   (defun insert    (ele lst)
  7.     (cond
  8.       ((null lst) (list ele))
  9.       ((> ele (car lst)) (cons ele lst))
  10.       ((cons (car lst) (insert ele (cdr lst))))
  11.     )
  12.   )
  13.
  14.   (if lst
  15.     (insert (car lst) (G:InsertSort (cdr lst)))
  16.   )
  17. )
  18.
  19.
  20.
  21. (defun anum (lst / lastitm neg missing doup)
  22.   (foreach itm (G:InsertSort (mapcar 'atoi lst))
  23.     (cond
  24.       ((minusp itm) (setq neg (cons itm neg)))
  25.       ((null lastitm) (setq lastitm itm))
  26.       ((= lastitm itm) ; douplicates
  27.            (setq doup (cons lastitm doup)
  28.                  lastitm itm)
  29.        )
  30.       ((if (/= (1- lastitm) itm) ; missing from list
  31.            (progn (while (/= (1- lastitm) itm)
  32.              (setq missing (cons (1- lastitm) missing)
  33.                  lastitm (1- lastitm)))(setq lastitm (1- lastitm)))
  34.            (setq lastitm itm)
  35.          )
  36.        )
  37.     )
  38.   )
  39.   (list neg missing doup)
  40. )
« Reply #11 on: March 31, 2017, 07:17:35 PM »
I like your method Alan - here is another variation, using the same process:
  1. (defun checklist ( l / d i m r )
  2.     (foreach x l
  3.         (if (wcmatch x "*[~0-9]*")
  4.             (or (member x i) (setq i (cons x i)))
  5.             (setq r (cons (atoi x) r))
  6.         )
  7.     )
  8.     (mapcar
  9.        '(lambda ( a b )
  10.             (cond
  11.                 (   (= a b) (or (member (itoa a) d) (setq d (cons (itoa a) d))))
  12.                 (   (< 1 (- b a))
  13.                     (while (< (setq a (1+ a)) b) (setq m (cons (itoa a) m)))
  14.                 )
  15.             )
  16.         )
  17.         (setq r (qs r)) (cdr r)
  18.     )
  19.     (princ "\nInvalid items: ")
  20.     (prin1 i)
  21.     (princ "\nMissing items: ")
  22.     (prin1 m)
  23.     (princ "\nDuplicate items: ")
  24.     (prin1 d)
  25.     (princ)
  26. )
  27. (defun qs ( l )
  28.     (   (lambda ( f ) (if l (f (car l) (cdr l))))
  29.         (lambda ( x l / a b )
  30.             (foreach y l
  31.                 (if (< y x)
  32.                     (setq a (cons y a))
  33.                     (setq b (cons y b))
  34.                 )
  35.             )
  36.             (append (qs a) (cons x (qs b)))
  37.         )
  38.     )
  39. )
David Bethel
« Reply #12 on: April 01, 2017, 06:38:04 AM »
(defun qs ( l )
            (foreach y l
                (if (< y x)
                    (setq a (cons y a))
                    (setq b (cons y b))
I must admit, that is 1 of the simplest sorting functions I've seen.  Nice
Thanks!  -David
« Last Edit: April 01, 2017, 06:47:05 AM by David Bethel »
R12 Dos - A2K
« Reply #13 on: April 01, 2017, 07:23:51 AM »
Thanks David!  :-)
« Reply #14 on: April 01, 2017, 08:28:47 AM »
Nice job Lee  8)
