Author Topic: Civil 3D pipe network  (Read 3594 times)
cyclops
« on: March 28, 2017, 02:34:47 PM »
I have a drawing with a civil 3d pipe network (structures & pipes),
I have a drawing with the cities asset numbers.
I need to add the asset number to the civil 3d pipe network structures & pipes.
How can I automate this process with very little user interaction, can a lisp routine let me select the asset number, then select the structure/pipe that needs the asset number.
The lisp routine would add the asset number to the structure/pipe "NAME" component.
Thanks for the help in advance.
Cyclops
It's 'O'Neill', with three L's!!!! (Jack O'Neill)
rkmcswain
Re: Civil 3D pipe network
« Reply #1 on: March 28, 2017, 03:40:30 PM »
...can a lisp routine let me select the asset number
Select it from what? Where will these asset numbers be?
cyclops
« Reply #2 on: March 28, 2017, 03:46:26 PM »
rkmcswain,
The asset number is a piece of text in the drawing, they are also available as object data assigned to line work in the drawing.
Thanks,
CyclOps
rkmcswain
« Reply #3 on: March 28, 2017, 03:55:07 PM »
In a most basic form, this will work.
(defun c:foo ()
  (setq sel (entsel "\nSelect Text"))
  (setq ent (entget (car sel)))
  (setq str (cdr (assoc 1 ent)))
  (setq sel (entsel "\nSelect Pipe/Structure"))
  (setq ent (car sel))
  (setq obj (vlax-ename->vla-object ent))
  (vla-put-name obj str)
cyclops
« Reply #4 on: March 28, 2017, 03:58:26 PM »
rkmcswain,
I'll try this.
Thanks!
CyclOps
« Reply #5 on: August 28, 2017, 09:42:35 AM »
I know this is late, but
If the city has this stuff in a GIS database,
then create your network from the database.  Look at Import GIS data.
It should maintain the asset information.
cyclops
« Reply #6 on: August 28, 2017, 10:06:41 AM »
The City had a database, it was not "compatible" with C3D pipes and the pipes were already in, when we found out that the city wanted the asset number added.
Thanks for the reply anyway.
Cycl0ps
