Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
How to get insertionpoint of block when select attribute
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How to get insertionpoint of block when select attribute (Read 1472 times)
HasanCAD
Swamp Rat
on:
March 27, 2017, 09:24:47 AM »
HI all
when select attribute (vlax-get objVL 'insertionpoint) gives the attribute insertionpoint
How to get the block insertionpoint?
This what I am using
Code - Auto/Visual Lisp:
[Select]
setq
obj
car
nentsel
\n
Select Origin attribute/Text : "
setq
objVL
vlax
ename
vla-object
obj
setq
objVL
Strng
vlax-get
objVL 'textstring
setq
objVL
inspnt
vlax-get
Logged
Sorry for my English.
Donate to Theswamp
www.sergiwa.com
Grrr1337
Swamp Rat
WWW
Re: How to get insertionpoint of block when select attribute
Reply #1 on:
March 27, 2017, 09:36:32 AM »
Using activex, probably like this:
[Select]
and
setq
att
car
nentsel
\n
Select attribute: "
"ATTRIB"
cdr
assoc
0
entget
att
setq
attobj
vlax
ename
vla-object
att
setq
blkobj
vla-ObjectIdToObject
vla-get-ActiveDocument
vlax-get-acad-object
vla-get-OwnerID
attobj
setq
attpt
vlax-get
attobj 'InsertionPoint
setq
blkpt
vlax-get
blkobj 'InsertionPoint
; and
Logged
(apply ''((a b c)(a b c))
vevo.bg
Pepe
Newt
Reply #2 on:
March 27, 2017, 09:50:38 AM »
Just for comparing with plain Autolisp...
[Select]
and
setq
att
car
nentsel
\n
Select attribute: "
"ATTRIB"
cdr
assoc
0
entget
att
setq
attobj
vlax
ename
vla-object
att
setq
blkobj
cdr
assoc
330
entget
att
setq
attpt
vlax-get
setq
blkpt
cdr
assoc
10
entget
blkobj
; and
Regards.
Logged
HasanCAD
Swamp Rat
Reply #3 on:
March 28, 2017, 01:47:42 AM »
Thanks Grrr1337
Thanks Pepe
both solutions are working perfect.
Logged
Donate to Theswamp
www.sergiwa.com
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
