Files are setup with all title blocks, details, dims, everything 100% in model space.
Some files have 1 title block per file, some files have 50, 60, 80, 100 drawings / title blocks per file.
Drawings are done true scale, 1:1 and title blocks are scaled up to properly fit.
In model space if you plot any title block... window to scale, window to fit or extents it comes out correct.
I want to get all tweaked to be able to publish from paper space.
I was thinking of putting a viewport to the proper scale in paper space and go through the page setup manager to be able to publish. The only thing in paper space would be the viewport.
The problem I have is that I am not sure how to get it setup so that the bottom left corner of the title block that is in model space is always in the exact same spot on paper space.
I'm sure there is a smart way to do this but I'm struggling with it.
