Author Topic: Copy Paste in Autocad importing other styles.  (Read 1932 times)
dubb
« on: March 22, 2017, 07:25:09 PM »
When I copy and paste a single line from one dwg to another, the dimension style and text styles are imported as well. I am trying to clean out a drawing from the styles. Why does Autocad import these styles when I didn't select them in my clipboard?  :idiot2:
Rob...
Re: Copy Paste in Autocad importing other styles.
« Reply #1 on: March 22, 2017, 07:34:46 PM »
Old issue. Best not to do that when cleaning files.
CAD Tech
roy_043
  • BricsCAD 18
« Reply #2 on: March 23, 2017, 03:06:13 PM »
Is there a dimension associated with the entity?
dubb
« Reply #3 on: March 24, 2017, 02:59:28 PM »
There isn't any dimension associated. I tested copy & paste a simple line from to as clean dwg file and it transferred over styles that I didn't select.
Rob...
« Reply #4 on: March 24, 2017, 03:02:25 PM »
Again, it's bad practice to copy/paste from a "dirty" file to a "clean" file for just this reason. Best to create from scratch.
CAD Tech
tedg
« Reply #5 on: March 27, 2017, 10:30:21 AM »
Or use Design Center and drag over only the content you want, dimstyles, textstyles, layers, layouts etc...
Usually from an up to date (not "dirty") template.
That's what I would do..
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
rkmcswain
« Reply #6 on: March 28, 2017, 03:44:30 PM »
In between the copy and the paste (in other words, after you do the copy) --- open your %temp% folder, find the latest file with a name like this [A$C64A2528C.DWG] and then open it. Does this extra stuff exist in that file?
And is it just one text style and dimstyle? Because the current dimstyle and textstyle get brought over.
