Author Topic: Updating MTEXT C#  (Read 3551 times)
nocent
Updating MTEXT C#
« on: March 22, 2017, 03:53:31 PM »
Update: Resolved by only passing in 1 argument into this method.
Hi all,
Beginner developer and autocad API user here whos had no luck googling this.  Hoping someone can point me in the right direction.
The goal is to update the mtext .contents.  The following code "opened .ForRead" can read mtext.contents perfectly fine. However, when i try to ".forWrite" i get the following exception:
Autodesk.AutoCAD.Runtime.Exception' in AcdbMgd.dll
Walking through the code it fails on line:
var obj = tr.GetObject(id, OpenMode.ForRead);
- but only on write mode.
The handle im passing in points back to an mtext object, and appears to be getting the correct object ID during conversion.  I havent eliminated this to be cause the caues of the problem however.
Does anyone have any code i can refer to for updating MText or could point me in the right direction?
public static void editMtextContents(string handle, string newValue)
Database db = doc.Database;
Handle hn = new Handle(ConvertHandleToInt(handle));
Transaction tr = db.TransactionManager.StartTransaction();
using (tr)
ObjectId id = db.GetObjectId(false, hn, 0);
var obj = tr.GetObject(id, OpenMode.ForWrite, false);
var mtext = obj as MText;
mtext.Contents = newValue;
tr.Commit();
Thanks!  -Bruce
Updates:
  • Using Autocad 2015
  • Drawings/layers arent locked
« Last Edit: March 23, 2017, 09:15:11 AM by nocent »
Jeff H
Re: Updating MTEXT C#
« Reply #1 on: March 22, 2017, 06:42:00 PM »
Was there anymore information with error?
Maybe on locked layer?
nocent
« Reply #2 on: March 23, 2017, 07:32:32 AM »
The layers arent locked, ive tried it on several drawings to try to weed out that dwg itself being the issue.
This is with using autocad 2015.
MexicanCustard
« Reply #3 on: March 23, 2017, 08:19:04 AM »
Can you post the drawing your working in?
nocent
« Reply #4 on: March 23, 2017, 09:12:15 AM »
I came through the issue (workaround?)!
The method doesnt work when passing in two arguments.  The fix was to fix the method signature to accept one argument, in my case an object that carried the handle and new value.
Phew!
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #5 on: March 24, 2017, 12:17:57 AM »
@ nocent,
Sorry, I can't quite grasp your description of your solution.
Can you post the revised method please ? And show how you are calling the method.
Also, how are you determining the handle, do you have the string stored somewhere as external data ?
Regards,
Called Kerry in my other life
I live at UTC + 13.00
nocent
« Reply #6 on: March 24, 2017, 03:57:54 PM »
Hi Ken,
Method i was having trouble with (note i also had to add the "document lock" to solve the issue production):
public static void EditMtextContents(UpdatedTag tag)
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
//create handle from long int
Handle hn = new Handle(ConvertHandleToInt(tag.Handle));
//attempt to get an ObjectID for the handle
//open the object to edit it
using (DocumentLock doclock = doc.LockDocument())
Transaction tr = doc.TransactionManager.StartTransaction();
using (tr)
DBObject obj = tr.GetObject(id, OpenMode.ForWrite);
//testing editing mtext contents
MText mtext = obj as MText;
mtext.Contents = tag.NewValue;
tr.Commit();
Updated tag is just a small simple class:
public class UpdatedTag
public string Handle { get; set; }
public string NewValue { get; set; }
public UpdatedTag(string handle, string newValue)
Handle = handle;
NewValue = newValue;
I extract all the mtext and store it in a list/dataset.  part of that information is its "handle" in acad terms.
i convert the string handle to an autocad object handle using (i believe i got this off from Kean, either way hes been a huge resource):
Handle = handle;
Hope this is more helpful than confusing - am very much new to acad and development in general :)
MexicanCustard
« Reply #7 on: March 27, 2017, 07:57:50 AM »
Are you storing the UpdatedTag object between sessions?  If not, then why not just use the ObjectId?
MexicanCustard
« Reply #8 on: March 27, 2017, 07:59:39 AM »
Also instead of
Code - C#: [Select]
  1. Transaction tr = doc.TransactionManager.StartTransaction();
  2.                 using (tr)
You can
Code - C#: [Select]
  1. using (Transaction tr = doc.TransactionManager.StartTransaction())
MexicanCustard
« Reply #9 on: March 27, 2017, 08:07:36 AM »
if your in C# 6
Code - C#: [Select]
  1. using (var doclock = doc.LockDocument())
  2.         {
  3.                 using (var tr = doc.TransactionManager.StartTransaction();)
  4.                 {
  5.                         var mtext = tr.GetObject(id, OpenMode.ForWrite) as MText;
  6.                         if(mtext != null)
  7.                         {
  8.                                mtext.Contents = tag.NewValue;
  9.                          }
  10.
  11.                         tr.Commit();
  12.                 }
  13.         }
If you've started using C#7
Code - C#: [Select]
  2.         {
  3.                 using (var tr = doc.TransactionManager.StartTransaction())
  4.                 {
  5.                        if(tr.GetObject(id, OpenMode.ForWrite) is MText mtext)
  6.                               mtext.Contents = tag.NewValue;
  7.                         tr.Commit();
  8.                 }
  9.         }
nocent
« Reply #10 on: March 28, 2017, 08:28:41 AM »
Its a single session.  Thanks for sharing the improved code, much better readability!  :-D
