Author Topic: CAD colors to True RGB Colors  (Read 143 times)
MSTG007
« on: March 17, 2017, 07:19:53 am »
Is there an easy way to convert all the standard CAD colors to True Color RGB? I have a drawing that has a all the CAD colors that are drawn in rectangle form with the color hard coded. I was hoping to convert those over.
Thanks for any help.
Autodesk Infrastructure Design Suite 2016
Chris
Re: CAD colors to True RGB Colors
« Reply #1 on: March 17, 2017, 07:37:37 am »
not an easy way to adjust the drawing, but possibly you could trick it by adjusting your plot style when printing.  There may be a lisp routine out there, it wouldnt make much sense to write one for a one and done, as it would take longer to write the routine then it would to just change the colors manually.
Christopher T. Cowgill, P.E.
WIGHTMAN & ASSOCIATES, INC.
ENGINEERING * SURVEYING * ARCHITECTURE
Autodesk Infrastructure Design Suite 2017
Win 10
Chris
« Reply #2 on: March 17, 2017, 07:43:15 am »
sorry, that last post wasnt exactly helpful, so I did some searching.  Lee-Mac has some stuff, here is one, not sure if it does what you want, but it looks like the coding wasnt as complex as I thought it would be:
http://www.cadtutor.net/forum/showthread.php?65645-Convert-from-index-colours-to-true-colours
Win 10
