Can a dynamic block be created and given dynamic parameters using autolisp/vlisp? I've been searching for a while and have not found a way to achieve this. I already have a way to select the objects I want in the block, just can't figure out how to usie lisp to make the dynamic block.
I've tried using (command "_-bedit" "blockname"), but it forces you to the edito, when I really want to add parameters using lisp only.
