Dear mr. Lee Mac. Amazing efficient stuff.
Beautiful! Thanks Lee
Thank you
Could you point out what part is the 'make it 0' that makes DIMSE1 and DIMSE1 turn off.
Could use it to toggle.
Note that the sample program above is applying a dimension style override only to the selected dimensions and not an override to the active dimension style itself, therefore the program will not affect the values of the
DIMSE1 &
DIMSE2 system variables.
A toggle of this nature is possible but far more complex to implement, as the program would need to retrieve the dimension style override xdata, parse the xdata into pairs of system variable codes and associated values, test for the presence of 75 & 76 and toggle the associated values if present; however, if the codes corresponding to these system variables are
not present, the program would also need to check whether the dimension style is already suppressing either extension line in order to determine the appropriate value to be added as a dimension style override (e.g. the dimension style may already be suppressing the first extension line, therefore to achieve a true toggle, the program would need to override this suppression).
