Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Fast question
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Fast question (Read 1119 times)
amc.dicsac
Newt
Autocad 2008
WWW
Fast question
on:
March 09, 2017, 02:50:44 PM »
Hi.
Is there any way to include a .SLD inside a .LSP
Code - Auto/Visual Lisp:
[Select]
setq
vectorlists
list
list
"C"
2
2
12
2
19
"C"
2
3
9
3
22
4
23
4
8
"C"
2
5
6
5
25
6
26
6
5
7
5
7
26
8
27
8
4
9
3
9
28
10
28
10
3
11
3
11
28
12
29
12
2
13
2
13
29
14
29
14
2
15
2
15
29
16
29
16
2
17
2
17
29
18
29
18
2
19
2
19
29
20
28
20
3
21
3
21
28
22
28
22
3
23
4
23
27
24
26
24
5
25
5
25
26
26
25
26
6
"C"
2
27
8
27
23
28
22
28
9
"C"
2
29
19
29
12
list
"C"
250
12
30
19
30
20
29
22
29
24
27
25
27
27
25
27
24
29
22
29
20
30
19
30
12
29
11
29
9
27
7
27
6
25
4
24
4
22
2
20
2
19
1
12
1
11
2
9
2
7
4
6
4
4
6
4
7
2
9
2
11
1
12
1
19
2
20
2
22
4
24
4
25
6
27
7
27
9
29
11
29
"C"
250
6
18
8
20
9
20
10
21
12
21
13
22
18
22
19
21
21
21
22
20
23
20
25
18
"C"
250
11
12
11
10
12
9
12
13
13
12
13
10
"C"
250
18
12
18
10
19
9
19
13
20
12
20
10
list
"C"
8
7
28
8
29
"C"
8
14
32
21
32
"C"
8
10
30
11
30
11
31
24
31
25
30
20
30
"C"
8
27
29
23
29
24
28
28
28
29
27
26
27
27
26
29
26
29
23
28
24
28
25
"C"
8
30
20
30
25
31
24
31
11
30
11
30
10
"C"
8
32
21
32
14
"C"
8
28
7
29
8
Last Edit: March 09, 2017, 04:33:24 PM by amc.dicsac
Logged
<a href="http:/http://axprogramlisp.blogspot.pe" class="bbc_link" target="_blank">By Alexander Castro</a>
David Bethel
Swamp Rat
WWW
Re: Fast question
Reply #1 on:
March 10, 2017, 09:52:01 AM »
If you are trying to display a true autocad slide file, look into (command"_.VSLIDE" .....). Otherwise (grvecs ) may be of use. But not in a dcl application. Menu files can also handle slide files. -David
At least in older acad releases
Logged
R12 Dos - A2K
dgorsman
Water Moccasin
Re: Fast question
Reply #2 on:
March 10, 2017, 10:10:15 AM »
The old "tile menu" should still be available as a legacy item. But I'd advise either switching to OpenDCL or rolling your own with dotNET (it's actually a good introductory task) since they can handle image files.
Logged
try {GreatPower;}
catch (notResponsible)
{NextTime(PlanAhead);}
finally
{MasterBasics;}
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Fast question
