Author Topic: Color converter not relying on acad  (Read 4854 times)
jmaeding
« on: March 06, 2017, 09:14:41 PM »
I have a program I did using acad color functions, but want it to run without acad.
I can easily do a lookup table for ACI (index color, 1 -255) to truecolor and knock that one out.
Has anyone looked at how acad converts truecolor to ACI though?
I bet its something simple, but have not played with it. I'll post if I figure it out.
thanks
James Maeding
huiz
  • Certified Prof C3D
Re: Color converter not relying on acad
« Reply #1 on: March 07, 2017, 01:59:56 AM »
Maybe there is an algoritm but I doubt. Aren't the first colors the Rothring pen widths?
You also could write a loop through the ACI colors and write the RGB colors in a CSV. Just a few lines of code.
jmaeding
« Reply #2 on: March 07, 2017, 11:22:31 AM »
no, other way around. You would loop through all the rgb combinations and make a lookup list of ACI numbers.
I'll take a whack at it.
James Maeding
dgorsman
« Reply #3 on: March 07, 2017, 12:08:23 PM »
Actually the other way around might be better.  It should be easier to loop through the ACI list and find the equivalent TrueColor that is "close enough" (unlikely to find something absolutely equal).  Otherwise that's a looooong list of RGB possibilities.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
zoltan
« Reply #4 on: March 07, 2017, 12:35:47 PM »
16,777,216 to be exact!
gile
  • Marseille, France
« Reply #5 on: March 07, 2017, 01:18:01 PM »
Attached a little .cs file which mainly defines a static Dictionary<int, System.Drawing.Color> where the key is the ACI code.
Usage:
System.Drawing.Color color = Aci.Color[40];
The .cs file has been generated from AutoCAD with this little F# routine (easily convertible to C#)
module ColorLookup
open Autodesk.AutoCAD.Runtime
open Autodesk.AutoCAD.Colors
open System.Drawing
open System.IO
[<CommandMethod("Test")>]
let test () =
    use writer = new StreamWriter(@"C:\Temp\ACI2RGB.cs")
    writer.Write(@"using System.Collections.Generic;
namespace System.Drawing
    public static class Aci
        public static Dictionary<int, Color> Color = new Dictionary<int, Color>
    [1s..254s] |> List.iter (fun i ->
        let c = Color.FromColorIndex(ColorMethod.ByAci, i).ColorValue
        writer.WriteLine(sprintf "            [%d] = System.Drawing.Color.FromArgb(%d, %d, %d)," i c.R c.G c.B))
    writer.WriteLine("            [255] = System.Drawing.Color.FromArgb(255, 255, 255)")
    writer.Write(@"        };
EDIT:
Oops, sorry I misunderstood the OP...
EDIT:
My apologies but I had to change the code tags. For some reason they were producing hundreds of errors per day.
« Last Edit: March 09, 2017, 06:30:01 AM by Mark »
jmaeding
« Reply #6 on: March 07, 2017, 02:18:53 PM »
Sorry, Gile, just saw you edited your reply, ignore my response below....
But list of rgb from index is trivial.
I am talking about take any rgb, and get the acad index color, but without acad.
However, we can and should use acad to help us figure that out.
I need this because I have a program that lets you set up stuff to be done in acad later, though it does not run in acad, and I don't want references to acad dlls.
James Maeding
jmaeding
« Reply #7 on: March 07, 2017, 08:48:07 PM »
Got it working, and tested against all 16 million colors using acad api.
My functions do not have that test in them of course, these are the final result and are fast.
They could be improved a lot if someone needed really fast lookup, this is brute force looping.
The idea came from stackoverflow but I assembled the code here and did the lookup table function.
Note that my background is black, as apparently the acad function for this changes depending on it.
I actually want it to be consistent, so I might say this one is better than adesk's.
public short GetACIfromRGB(short r, short g, short b) {
            Dictionary<short, List<short>> lookup = ACItoRGBLookup();
            //now get color using shortest dist calc and see if it matches
            double minDist = double.MaxValue;
            short match = 0; // this will end up with our answer
            for (short i = 1; i <= 255; ++i) {
                List<short> lookupcolor = lookup[i];
                double dist =
                    Math.Pow(r - lookupcolor[0], 2) +
                    Math.Pow(g - lookupcolor[1], 2) +
                    Math.Pow(b - lookupcolor[2], 2);
                if (dist < minDist) {
                    minDist = dist;
                    match = i;
            return match;
public Dictionary<short, List<short>> ACItoRGBLookup() {
            Dictionary<short, List<short>> ret = new Dictionary<short, List<short>>();
            ret.Add(1, new List<short>() { 255, 0, 0 });
            ret.Add(2, new List<short>() { 255, 255, 0 });
            ret.Add(3, new List<short>() { 0, 255, 0 });
            ret.Add(4, new List<short>() { 0, 255, 255 });
            ret.Add(5, new List<short>() { 0, 0, 255 });
            ret.Add(6, new List<short>() { 255, 0, 255 });
            ret.Add(7, new List<short>() { 255, 255, 255 });
            ret.Add(8, new List<short>() { 128, 128, 128 });
            ret.Add(9, new List<short>() { 192, 192, 192 });
            ret.Add(10, new List<short>() { 255, 0, 0 });
            ret.Add(11, new List<short>() { 255, 127, 127 });
            ret.Add(12, new List<short>() { 204, 0, 0 });
            ret.Add(13, new List<short>() { 204, 102, 102 });
            ret.Add(14, new List<short>() { 153, 0, 0 });
            ret.Add(15, new List<short>() { 153, 76, 76 });
            ret.Add(16, new List<short>() { 127, 0, 0 });
            ret.Add(17, new List<short>() { 127, 63, 63 });
            ret.Add(18, new List<short>() { 76, 0, 0 });
            ret.Add(19, new List<short>() { 76, 38, 38 });
            ret.Add(20, new List<short>() { 255, 63, 0 });
            ret.Add(21, new List<short>() { 255, 159, 127 });
            ret.Add(22, new List<short>() { 204, 51, 0 });
            ret.Add(23, new List<short>() { 204, 127, 102 });
            ret.Add(24, new List<short>() { 153, 38, 0 });
            ret.Add(25, new List<short>() { 153, 95, 76 });
            ret.Add(26, new List<short>() { 127, 31, 0 });
            ret.Add(27, new List<short>() { 127, 79, 63 });
            ret.Add(28, new List<short>() { 76, 19, 0 });
            ret.Add(29, new List<short>() { 76, 47, 38 });
            ret.Add(30, new List<short>() { 255, 127, 0 });
            ret.Add(31, new List<short>() { 255, 191, 127 });
            ret.Add(32, new List<short>() { 204, 102, 0 });
            ret.Add(33, new List<short>() { 204, 153, 102 });
            ret.Add(34, new List<short>() { 153, 76, 0 });
            ret.Add(35, new List<short>() { 153, 114, 76 });
            ret.Add(36, new List<short>() { 127, 63, 0 });
            ret.Add(37, new List<short>() { 127, 95, 63 });
            ret.Add(38, new List<short>() { 76, 38, 0 });
            ret.Add(39, new List<short>() { 76, 57, 38 });
            ret.Add(40, new List<short>() { 255, 191, 0 });
            ret.Add(41, new List<short>() { 255, 223, 127 });
            ret.Add(42, new List<short>() { 204, 153, 0 });
            ret.Add(43, new List<short>() { 204, 178, 102 });
            ret.Add(44, new List<short>() { 153, 114, 0 });
            ret.Add(45, new List<short>() { 153, 133, 76 });
            ret.Add(46, new List<short>() { 127, 95, 0 });
            ret.Add(47, new List<short>() { 127, 111, 63 });
            ret.Add(48, new List<short>() { 76, 57, 0 });
            ret.Add(49, new List<short>() { 76, 66, 38 });
            ret.Add(50, new List<short>() { 255, 255, 0 });
            ret.Add(51, new List<short>() { 255, 255, 127 });
            ret.Add(52, new List<short>() { 204, 204, 0 });
            ret.Add(53, new List<short>() { 204, 204, 102 });
            ret.Add(54, new List<short>() { 153, 153, 0 });
            ret.Add(55, new List<short>() { 153, 153, 76 });
            ret.Add(56, new List<short>() { 127, 127, 0 });
            ret.Add(57, new List<short>() { 127, 127, 63 });
            ret.Add(58, new List<short>() { 76, 76, 0 });
            ret.Add(59, new List<short>() { 76, 76, 38 });
            ret.Add(60, new List<short>() { 191, 255, 0 });
            ret.Add(61, new List<short>() { 223, 255, 127 });
            ret.Add(62, new List<short>() { 153, 204, 0 });
            ret.Add(63, new List<short>() { 178, 204, 102 });
            ret.Add(64, new List<short>() { 114, 153, 0 });
            ret.Add(65, new List<short>() { 133, 153, 76 });
            ret.Add(66, new List<short>() { 95, 127, 0 });
            ret.Add(67, new List<short>() { 111, 127, 63 });
            ret.Add(68, new List<short>() { 57, 76, 0 });
            ret.Add(69, new List<short>() { 66, 76, 38 });
            ret.Add(70, new List<short>() { 127, 255, 0 });
            ret.Add(71, new List<short>() { 191, 255, 127 });
            ret.Add(72, new List<short>() { 102, 204, 0 });
            ret.Add(73, new List<short>() { 153, 204, 102 });
            ret.Add(74, new List<short>() { 76, 153, 0 });
            ret.Add(75, new List<short>() { 114, 153, 76 });
            ret.Add(76, new List<short>() { 63, 127, 0 });
            ret.Add(77, new List<short>() { 95, 127, 63 });
            ret.Add(78, new List<short>() { 38, 76, 0 });
            ret.Add(79, new List<short>() { 57, 76, 38 });
            ret.Add(80, new List<short>() { 63, 255, 0 });
            ret.Add(81, new List<short>() { 159, 255, 127 });
            ret.Add(82, new List<short>() { 51, 204, 0 });
            ret.Add(83, new List<short>() { 127, 204, 102 });
            ret.Add(84, new List<short>() { 38, 153, 0 });
            ret.Add(85, new List<short>() { 95, 153, 76 });
            ret.Add(86, new List<short>() { 31, 127, 0 });
            ret.Add(87, new List<short>() { 79, 127, 63 });
            ret.Add(88, new List<short>() { 19, 76, 0 });
            ret.Add(89, new List<short>() { 47, 76, 38 });
            ret.Add(90, new List<short>() { 0, 255, 0 });
            ret.Add(91, new List<short>() { 127, 255, 127 });
            ret.Add(92, new List<short>() { 0, 204, 0 });
            ret.Add(93, new List<short>() { 102, 204, 102 });
            ret.Add(94, new List<short>() { 0, 153, 0 });
            ret.Add(95, new List<short>() { 76, 153, 76 });
            ret.Add(96, new List<short>() { 0, 127, 0 });
            ret.Add(97, new List<short>() { 63, 127, 63 });
            ret.Add(98, new List<short>() { 0, 76, 0 });
            ret.Add(99, new List<short>() { 38, 76, 38 });
            ret.Add(100, new List<short>() { 0, 255, 63 });
            ret.Add(101, new List<short>() { 127, 255, 159 });
            ret.Add(102, new List<short>() { 0, 204, 51 });
            ret.Add(103, new List<short>() { 102, 204, 127 });
            ret.Add(104, new List<short>() { 0, 153, 38 });
            ret.Add(105, new List<short>() { 76, 153, 95 });
            ret.Add(106, new List<short>() { 0, 127, 31 });
            ret.Add(107, new List<short>() { 63, 127, 79 });
            ret.Add(108, new List<short>() { 0, 76, 19 });
            ret.Add(109, new List<short>() { 38, 76, 47 });
            ret.Add(110, new List<short>() { 0, 255, 127 });
            ret.Add(111, new List<short>() { 127, 255, 191 });
            ret.Add(112, new List<short>() { 0, 204, 102 });
            ret.Add(113, new List<short>() { 102, 204, 153 });
            ret.Add(114, new List<short>() { 0, 153, 76 });
            ret.Add(115, new List<short>() { 76, 153, 114 });
            ret.Add(116, new List<short>() { 0, 127, 63 });
            ret.Add(117, new List<short>() { 63, 127, 95 });
            ret.Add(118, new List<short>() { 0, 76, 38 });
            ret.Add(119, new List<short>() { 38, 76, 57 });
            ret.Add(120, new List<short>() { 0, 255, 191 });
            ret.Add(121, new List<short>() { 127, 255, 223 });
            ret.Add(122, new List<short>() { 0, 204, 153 });
            ret.Add(123, new List<short>() { 102, 204, 178 });
            ret.Add(124, new List<short>() { 0, 153, 114 });
            ret.Add(125, new List<short>() { 76, 153, 133 });
            ret.Add(126, new List<short>() { 0, 127, 95 });
            ret.Add(127, new List<short>() { 63, 127, 111 });
            ret.Add(128, new List<short>() { 0, 76, 57 });
            ret.Add(129, new List<short>() { 38, 76, 66 });
            ret.Add(130, new List<short>() { 0, 255, 255 });
            ret.Add(131, new List<short>() { 127, 255, 255 });
            ret.Add(132, new List<short>() { 0, 204, 204 });
            ret.Add(133, new List<short>() { 102, 204, 204 });
            ret.Add(134, new List<short>() { 0, 153, 153 });
            ret.Add(135, new List<short>() { 76, 153, 153 });
            ret.Add(136, new List<short>() { 0, 127, 127 });
            ret.Add(137, new List<short>() { 63, 127, 127 });
            ret.Add(138, new List<short>() { 0, 76, 76 });
            ret.Add(139, new List<short>() { 38, 76, 76 });
            ret.Add(140, new List<short>() { 0, 191, 255 });
            ret.Add(141, new List<short>() { 127, 223, 255 });
            ret.Add(142, new List<short>() { 0, 153, 204 });
            ret.Add(143, new List<short>() { 102, 178, 204 });
            ret.Add(144, new List<short>() { 0, 114, 153 });
            ret.Add(145, new List<short>() { 76, 133, 153 });
            ret.Add(146, new List<short>() { 0, 95, 127 });
            ret.Add(147, new List<short>() { 63, 111, 127 });
            ret.Add(148, new List<short>() { 0, 57, 76 });
            ret.Add(149, new List<short>() { 38, 66, 76 });
            ret.Add(150, new List<short>() { 0, 127, 255 });
            ret.Add(151, new List<short>() { 127, 191, 255 });
            ret.Add(152, new List<short>() { 0, 102, 204 });
            ret.Add(153, new List<short>() { 102, 153, 204 });
            ret.Add(154, new List<short>() { 0, 76, 153 });
            ret.Add(155, new List<short>() { 76, 114, 153 });
            ret.Add(156, new List<short>() { 0, 63, 127 });
            ret.Add(157, new List<short>() { 63, 95, 127 });
            ret.Add(158, new List<short>() { 0, 38, 76 });
            ret.Add(159, new List<short>() { 38, 57, 76 });
            ret.Add(160, new List<short>() { 0, 63, 255 });
            ret.Add(161, new List<short>() { 127, 159, 255 });
            ret.Add(162, new List<short>() { 0, 51, 204 });
            ret.Add(163, new List<short>() { 102, 127, 204 });
            ret.Add(164, new List<short>() { 0, 38, 153 });
            ret.Add(165, new List<short>() { 76, 95, 153 });
            ret.Add(166, new List<short>() { 0, 31, 127 });
            ret.Add(167, new List<short>() { 63, 79, 127 });
            ret.Add(168, new List<short>() { 0, 19, 76 });
            ret.Add(169, new List<short>() { 38, 47, 76 });
            ret.Add(170, new List<short>() { 0, 0, 255 });
            ret.Add(171, new List<short>() { 127, 127, 255 });
            ret.Add(172, new List<short>() { 0, 0, 204 });
            ret.Add(173, new List<short>() { 102, 102, 204 });
            ret.Add(174, new List<short>() { 0, 0, 153 });
            ret.Add(175, new List<short>() { 76, 76, 153 });
            ret.Add(176, new List<short>() { 0, 0, 127 });
            ret.Add(177, new List<short>() { 63, 63, 127 });
            ret.Add(178, new List<short>() { 0, 0, 76 });
            ret.Add(179, new List<short>() { 38, 38, 76 });
            ret.Add(180, new List<short>() { 63, 0, 255 });
            ret.Add(181, new List<short>() { 159, 127, 255 });
            ret.Add(182, new List<short>() { 51, 0, 204 });
            ret.Add(183, new List<short>() { 127, 102, 204 });
            ret.Add(184, new List<short>() { 38, 0, 153 });
            ret.Add(185, new List<short>() { 95, 76, 153 });
            ret.Add(186, new List<short>() { 31, 0, 127 });
            ret.Add(187, new List<short>() { 79, 63, 127 });
            ret.Add(188, new List<short>() { 19, 0, 76 });
            ret.Add(189, new List<short>() { 47, 38, 76 });
            ret.Add(190, new List<short>() { 127, 0, 255 });
            ret.Add(191, new List<short>() { 191, 127, 255 });
            ret.Add(192, new List<short>() { 102, 0, 204 });
            ret.Add(193, new List<short>() { 153, 102, 204 });
            ret.Add(194, new List<short>() { 76, 0, 153 });
            ret.Add(195, new List<short>() { 114, 76, 153 });
            ret.Add(196, new List<short>() { 63, 0, 127 });
            ret.Add(197, new List<short>() { 95, 63, 127 });
            ret.Add(198, new List<short>() { 38, 0, 76 });
            ret.Add(199, new List<short>() { 57, 38, 76 });
            ret.Add(200, new List<short>() { 191, 0, 255 });
            ret.Add(201, new List<short>() { 223, 127, 255 });
            ret.Add(202, new List<short>() { 153, 0, 204 });
            ret.Add(203, new List<short>() { 178, 102, 204 });
            ret.Add(204, new List<short>() { 114, 0, 153 });
            ret.Add(205, new List<short>() { 133, 76, 153 });
            ret.Add(206, new List<short>() { 95, 0, 127 });
            ret.Add(207, new List<short>() { 111, 63, 127 });
            ret.Add(208, new List<short>() { 57, 0, 76 });
            ret.Add(209, new List<short>() { 66, 38, 76 });
            ret.Add(210, new List<short>() { 255, 0, 255 });
            ret.Add(211, new List<short>() { 255, 127, 255 });
            ret.Add(212, new List<short>() { 204, 0, 204 });
            ret.Add(213, new List<short>() { 204, 102, 204 });
            ret.Add(214, new List<short>() { 153, 0, 153 });
            ret.Add(215, new List<short>() { 153, 76, 153 });
            ret.Add(216, new List<short>() { 127, 0, 127 });
            ret.Add(217, new List<short>() { 127, 63, 127 });
            ret.Add(218, new List<short>() { 76, 0, 76 });
            ret.Add(219, new List<short>() { 76, 38, 76 });
            ret.Add(220, new List<short>() { 255, 0, 191 });
            ret.Add(221, new List<short>() { 255, 127, 223 });
            ret.Add(222, new List<short>() { 204, 0, 153 });
            ret.Add(223, new List<short>() { 204, 102, 178 });
            ret.Add(224, new List<short>() { 153, 0, 114 });
            ret.Add(225, new List<short>() { 153, 76, 133 });
            ret.Add(226, new List<short>() { 127, 0, 95 });
            ret.Add(227, new List<short>() { 127, 63, 111 });
            ret.Add(228, new List<short>() { 76, 0, 57 });
            ret.Add(229, new List<short>() { 76, 38, 66 });
            ret.Add(230, new List<short>() { 255, 0, 127 });
            ret.Add(231, new List<short>() { 255, 127, 191 });
            ret.Add(232, new List<short>() { 204, 0, 102 });
            ret.Add(233, new List<short>() { 204, 102, 153 });
            ret.Add(234, new List<short>() { 153, 0, 76 });
            ret.Add(235, new List<short>() { 153, 76, 114 });
            ret.Add(236, new List<short>() { 127, 0, 63 });
            ret.Add(237, new List<short>() { 127, 63, 95 });
            ret.Add(238, new List<short>() { 76, 0, 38 });
            ret.Add(239, new List<short>() { 76, 38, 57 });
            ret.Add(240, new List<short>() { 255, 0, 63 });
            ret.Add(241, new List<short>() { 255, 127, 159 });
            ret.Add(242, new List<short>() { 204, 0, 51 });
            ret.Add(243, new List<short>() { 204, 102, 127 });
            ret.Add(244, new List<short>() { 153, 0, 38 });
            ret.Add(245, new List<short>() { 153, 76, 95 });
            ret.Add(246, new List<short>() { 127, 0, 31 });
            ret.Add(247, new List<short>() { 127, 63, 79 });
            ret.Add(248, new List<short>() { 76, 0, 19 });
            ret.Add(249, new List<short>() { 76, 38, 47 });
            ret.Add(250, new List<short>() { 51, 51, 51 });
            ret.Add(251, new List<short>() { 91, 91, 91 });
            ret.Add(252, new List<short>() { 132, 132, 132 });
            ret.Add(253, new List<short>() { 173, 173, 173 });
            ret.Add(254, new List<short>() { 214, 214, 214 });
            ret.Add(255, new List<short>() { 255, 255, 255 });
            return ret;
James Maeding
jmaeding
« Reply #8 on: March 07, 2017, 09:02:07 PM »
btw, test code was:
[CommandMethod("TESTCOL", CommandFlags.Session)]
        public void TestColorConv() {
            for (short ir = 0; ir < 256; ir++) {
                Debug.Print(ir.ToString());
                for (short ig = 0; ig < 256; ig++) {
                    for (short ib = 0; ib < 256; ib++) {
                        System.Drawing.Color clr = System.Drawing.Color.FromArgb(ir, ig, ib);
                        AcCo.Color ret = AcCo.Color.FromColorIndex(AcCo.ColorMethod.ByAci, AcCo.Color.FromRgb(clr.R, clr.G, clr.B).ColorIndex);
                        int ind = ret.ColorIndex;
                        short match = HAHelper.Colors.GetACIfromRGB(clr.R, clr.G, clr.B);
                        if (ind != match)
                            MessageBox.Show("its not a match");
I did not get the "its not a match" message a single time.
James Maeding
jmaeding
« Reply #9 on: March 08, 2017, 12:39:12 AM »
someone asked about these numbers
GetACIfromRGB(105, 142, 144)
answer is 252.
not sure what the issue was, ran clean for me.
James Maeding
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: March 08, 2017, 02:14:42 AM »
answer is 252.
lol, just checking
huiz
« Reply #11 on: March 08, 2017, 08:00:01 AM »
Ah you need ALL rgb colors.
I don't think there is a real connection between RGB and ACI. I think it is better to make a lookup table for all ACI colors from 10-249 and the RGB colors. Then if someone enters a RGB color, you look for the closest combination. I hope you will get the correct color then :-)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #12 on: March 08, 2017, 08:11:07 AM »
There’s actually a windows method for this, GetNearestPaletteIndex.
or the distance idea works too
« Last Edit: March 08, 2017, 05:15:29 PM by nullptr »
