Hi All,
I wrote some DOT NET routines a while back in AutoCAD 2010 using Visual Studio 2010, but now we are upgrading to AutoCAD 2017 / Visual Studio 2015.
I have successfully imported all of my code into the new environment, and everything works fine, except for the flyouts, toolbars, and toolbar buttons. These do not even show up at all in AutoCAD 2017 after the program is started up and my DLL is netloaded.
All the commands, however, still become available in AutoCAD, but only via command line.
What I'm attempting to accomplish is to have the flyouts appear automatically on the top-left everytime AutoCAD is started up.
Below is the myCommands.vb file which runs upon program initialization, and which should show me my flyouts in AutoCAD 2017, but doesn't:
Option Explicit On
Imports Microsoft.Win32
Imports System.Reflection
Imports System.Data.OleDb
Imports System.Runtime.CompilerServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Customization
Imports acOp = Autodesk.AutoCAD.Interop
Imports acOpCom = Autodesk.AutoCAD.Interop.Common
<Assembly: CommandClass(GetType(CatScript17.CatScriptCommands))>
Namespace CatScript17
' Manages all CatScript commands for this software. Also contains all the autocad flyout/toolbar commands.
Public Class CatScriptCommands
Implements IExtensionApplication
Public Shared strAppName As String = "CatScript17"
Public Shared cs As CustomizationSection
Public Shared restoreDefaultMacro As Boolean = False
Public Sub Initialize() Implements IExtensionApplication.Initialize
' Autoload the catscript17 flyouts and toolbars into AutoCAD 2017 upon each startup
CatScriptToolbar.addToolbar()
Public Sub Terminate() Implements IExtensionApplication.Terminate
Throw New NotImplementedException()
' Displaying the Air Conveyor Corner form
<CommandMethod("accorner", CommandFlags.UsePickSet)>
Public Shared Sub acCorner()
' Displaying the Air Conveyor Side Elevation form
<CommandMethod("acelevation", CommandFlags.UsePickSet)>
Public Shared Sub acElevation()
' Displaying the Air Conveyor Straight form
<CommandMethod("acstraight", CommandFlags.UsePickSet)>
Public Shared Sub acStraight()
' Displaying the Case Straight Combo form
<CommandMethod("cccombo", CommandFlags.UsePickSet)>
Public Shared Sub ccCombo()
' Displaying the Case Corner Conveyor form
<CommandMethod("cccorner", CommandFlags.UsePickSet)>
Public Shared Sub ccCorner()
' Displaying the Case Conveyor Side Elevation form
<CommandMethod("ccelevation", CommandFlags.UsePickSet)>
Public Shared Sub ccElevation()
' Displaying the Case Straight Conveyor form
<CommandMethod("ccstraight", CommandFlags.UsePickSet)>
Public Shared Sub ccStraight()
' Displaying the Case Turner Conveyor form
<CommandMethod("ccturner", CommandFlags.UsePickSet)>
Public Shared Sub ccTurner()
' Displaying the Case Zero Pressure Conveyor form
<CommandMethod("cczeropressure", CommandFlags.UsePickSet)>
Public Shared Sub ccZeroPressure()
' Displaying the table top Bi-Di form
<CommandMethod("ttbidi", CommandFlags.UsePickSet)>
Public Shared Sub ttBiDi()
' Displaying the table top Combiner form
<CommandMethod("ttcombiner", CommandFlags.UsePickSet)>
Public Shared Sub ttCombiner()
' Displaying the table top Corner form
<CommandMethod("ttcorner", CommandFlags.UsePickSet)>
Public Shared Sub ttCorner()
' Displaying the table top Decel form
<CommandMethod("ttdecel", CommandFlags.UsePickSet)>
Public Shared Sub ttDecel()
' Displaying the table top Divert form
<CommandMethod("ttdivert", CommandFlags.UsePickSet)>
Public Shared Sub ttDivert()
' Displaying the table top Dynamic form
<CommandMethod("ttdynamic", CommandFlags.UsePickSet)>
Public Shared Sub ttDynamic()
' Displaying the Table Top Side Elevation form
<CommandMethod("ttelevation", CommandFlags.UsePickSet)>
Public Shared Sub ttElevation()
' Displaying the Mass Merge Conveyor form
<CommandMethod("ttmerge", CommandFlags.UsePickSet)>
Public Shared Sub ttMerge()
' Displaying the Mass Parallel Conveyor form
<CommandMethod("ttparallel", CommandFlags.UsePickSet)>
Public Shared Sub ttParallel()
' Displaying the Mass Straight Conveyor form
<CommandMethod("ttstraight", CommandFlags.UsePickSet)>
Public Shared Sub ttStraight()
End Class
Public Class CatScriptToolbar
' Properties
Private Shared groups As acOp.AcadMenuGroups
Private Shared group As acOp.AcadMenuGroup
Private Shared toolbars As acOp.IAcadToolbars
Private Shared toolbar As acOp.AcadToolbar
Private Shared flyout As acOp.AcadToolbarItem
' Methods
' Component for adding toolbars and flyouts
Public Shared Sub addToolbar()
Try
Dim app As acOp.AcadApplication = _
DirectCast(Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication, _
acOp.AcadApplication)
' Define the toolbars group
groups = app.MenuGroups
group = groups.Item(0)
toolbars = group.Toolbars
' Generate the flyout toolbar
toolbar = toolbars.Add("CatScript Tools")
' Generate the flyouts
flyoutForTableTop(0)
flyoutForCaseConveyor(1)
flyoutForAirConveyor(2)
' Dock the newly created toolbar on the left
toolbar.Dock(acOpCom.AcToolbarDockStatus.acToolbarDockLeft)
Catch ex As System.Exception
End Try
' Component for generating the flyout for air conveyor, as well as buttons for each routine
Private Shared Sub flyoutForAirConveyor(ByVal toolbarIndex As Long)
' Create an air conveyor toolbar
Dim str As String = "Air"
Dim tool As acOp.AcadToolbar = toolbars.Add(str & " Conveyor")
Dim titles(), commands(), descs() As String
titles = {"Straight", "Corner", "Elevation"}
commands = {"straight", "corner", "elevation"}
descs = {"Generates the straight sections for air conveyor applications. " & _
"Allows for section dimensioning",
"Generates the curved sections and corners for air conveyor applications " & _
"(in angles of 30, 45, 60, and 90 degrees). User also has the option of generating " & _
"infinite curves (with legs or hangers) for the air conveyor corner",
"Generates the side and plan views of elevation changes for air conveyors. " & _
"This is accomplished using infeed and discharge NRE, incline/decline angle or " & _
"specified/picked distance, and infeed/discharge section lengths. This routine " & _
"allows for section dimensioning (if generating ONLY plan view)"}
Dim button As acOp.AcadToolbarItem
For i As Long = 0 To titles.Length - 1
' Add the button to temporary toolbar
button = tool.AddToolbarButton(i, str & " " & titles(i), _
descs(i), ChrW(27) & ChrW(27) & "_ac" & commands(i) & vbLf, False)
' Set the images for the button. cat.root is C:\catscript\
button.SetBitmaps(cat.root & "AC " & titles(i) & ".bmp", _
cat.root & "AC " & titles(i) & ".bmp")
Next
'Create the Group flyout
flyout = toolbar.AddToolbarButton(toolbarIndex, _
"Air Conveyor", "Groups the Air Conveyors", _
ChrW(27) & ChrW(27) & "_acstraight" & vbLf, True)
flyout.SetBitmaps(cat.root & "AC Straight.bmp", cat.root & "AC Straight.bmp")
' Attach the group toolbar to the flyout just created
flyout.AttachToolbarToFlyout(group.Name.ToString(), str & " Conveyor")
tool.Visible = False
' Component for generating the flyout for case conveyor, as well as buttons for each routine
Private Shared Sub flyoutForCaseConveyor(ByVal toolbarIndex As Long)
' Create a case conveyor toolbar
Dim tool As acOp.AcadToolbar = toolbars.Add("Case Conveyor")
titles = {"Straight", "Corner", "Turner", "Zero Pressure", "Elevation", "Combo"}
commands = {"straight", "corner", "turner", "zeropressure", "elevation", "combo"}
descs = {"Generates the straight sections for case conveyor applications. " & _
"Sections generated are Straight Idler, Pass Through, Drive, and Stand Alone, " & _
"using varying infeed and discharge styles. This routine allows " & _
"for section dimensioning",
"Generates the curved sections and corners in case conveyor applications",
"Generates the Straight Stand-Alone, and Multiple Chain sections of case " & _
"conveyor for product orientation change. This routine allows for section dimensioning",
"Generates straight sections of Zero-Pressure Accumulation in case " & _
"conveyor applications. This routine allows for section dimensioning",
"Generates the side and plan views of elevation changes for case conveyors. " & _
"This is accomplished using infeed and discharge TOC, incline/decline angle or " & _
"allows for section dimensioning (if generating ONLY plan view)", _
"Combines two or three case straight sections into one case straight section"}
button = tool.AddToolbarButton(i, "Case " & titles(i), _
descs(i), ChrW(27) & ChrW(27) & "_cc" & commands(i) & vbLf, False)
button.SetBitmaps(cat.root & "CC " & titles(i) & ".bmp", _
cat.root & "CC " & titles(i) & ".bmp")
Next
"Case Conveyor", "Groups the Case conveyors", _
ChrW(27) & ChrW(27) & "_ccstraight" & vbLf, True)
flyout.SetBitmaps(cat.root & "CC Straight.bmp", cat.root & "CC Straight.bmp")
flyout.AttachToolbarToFlyout(group.Name.ToString(), "Case Conveyor")
' Component for generating the flyout for table top, as well as buttons for each routine
Private Shared Sub flyoutForTableTop(ByVal toolbarIndex As Long)
' Create a table top toolbar
Dim tool As acOp.AcadToolbar = toolbars.Add("Table Top")
titles = {"Straight", "Corner", "Dynamic Transfer", "Parallel Transfer", _
"Merge", "Divert", "Combiner", "Decel"}
commands = {"straight", "corner", "dynamic", "parallel", _
"merge", "divert", "combiner", "decel"}
descs = {"Generates the straight sections for table top applications. " & _
"Sections generated are Straight Idler, Pass Through, Drive, and " & _
"Stand Alone. User has the option of specifying rail configuration, " & _
"Generates the curved sections and corners in table top applications.",
"Generates the dynamic transfer sections in table top applications. " & _
"User has the option of specifying rail configuration. " & _
"This routine allows for section dimensioning",
"Generates the parallel transfers in table top applications. User has the " & _
"option of specifying rail configuration. This routine allows for section dimensioning",
"Generates merge tables in table top applications. User has the option of " & _
"specifying rail configuration. This routine allows for section dimensioning",
"Generates divert tables in table top applications. User has the option of " & _
"Generates combiner tables in table top applications. " & _
"Generates deceleration tables in table top applications. " & _
"This routine allows for section dimensioning"}
' Generate the buttons
button = tool.AddToolbarButton(i, "Table Top " & titles(i), _
descs(i), ChrW(27) & ChrW(27) & "_tt" & commands(i) & vbLf, False)
button.SetBitmaps(cat.root & "TT " & titles(i) & ".bmp", _
cat.root & "TT " & titles(i) & ".bmp")
Next
"Table Top Conveyor", "Groups the Table Top conveyors", _
ChrW(27) & ChrW(27) & "_ttstraight" & vbLf, True)
flyout.SetBitmaps(cat.root & "TT Straight.bmp", cat.root & "TT Straight.bmp")
flyout.AttachToolbarToFlyout(group.Name.ToString(), "Table Top")
End Class
End Namespace
This project references the latest AutoCAD API DLLs from ObjectARX 2017.
Any ideas on how I can get this code to display those 3 flyouts and their toolbars?
Did AutoCAD change the way flyouts and toolbars are generated in AutoCAD 2017 VS2015?
If so, any pointers as to how I can autoload my flyouts and toolbars in AutoCAD 2017 upon program startup?
Thanks.
