CAD Forums > Vertically Challenged
Civil 3D 2017 - MapWSpace SLOOOOOOOOOW
alanjt:
Has anyone noticed when bringing in a SHP file with MAPWSPACE in c3d2017, if the SHP file has any significant amount of data, the file completely bogs down and you can't pan/zoom around?
Recently upgraded from 2014 and never had a problem.
I'm even loading the same SHP files in 2017 that were fine in previous c3d versions.
BlackBox:
I've not noticed that, although that may just be due to the fact that I generally MAPIMPORT Shapefiles, and only use MAPWSPACE for drawing queries of the imported Object Data.
What exactly are you 'bringing in' from the Shapefile(s) using MAPWSPACE?
The only thing I have noticed slowing a session to a crawl, is a pick of even a single imported Polyline that has too many vertices, with no real way to force a deselect (until the select is finished). GRIPOBJLIMIT only accounts for the number of entities selected, and not the max number of Grips to be displayed.
Cheers
mjfarrell:
is the data local, or on a network?
If on a network test with a local copy.
alanjt:
--- Quote from: mjfarrell on October 16, 2017, 09:36:35 AM ---is the data local, or on a network?
--- End quote ---
The data is on a network. I'll give it a try.
Odd thing is, it's been fine on previous version loading from a network drive.
mjfarrell:
--- Quote from: alanjt on October 16, 2017, 09:50:07 AM ---
--- End quote ---
--- End quote ---
It happens here quite a bit, due to excessive use of DFS (our data is somewhere in an AMAZON Server Rack)
But our contract IT people are infallible :uglystupid2: according to management.
Navigation
[0] Message Index
[#] Next page
Go to full version
