Author Topic: react like enter when press space bar with getsting function  (Read 3416 times)
Coder
« on: February 21, 2017, 05:41:33 AM »
Hello guys.
I am looking for a way to end the function (getstring t) when I press space bar as the first char instead of enter.
is there any way to solve this?
Thanks in advance.
(or *myString* (setq *myString* "Pile-01"))
(setq *myString* (getstring t (strcat "Name of pile < " *myString* " > :")))
Grrr1337
Re: react like enter when press space bar with getsting function
« Reply #1 on: February 21, 2017, 05:48:37 AM »
Tharwat helped me here.
The whole idea was to construct a list of strings, however his suggestion concatenates the inputed text into one big string.
But in that thread I was reffering about creating an MTEXT entity, IDK whats your intention here.
(apply ''((a b c)(a b c))
vevo.bg
Coder
« Reply #2 on: February 21, 2017, 06:02:27 AM »
Thank you for your help.
I think what I am after is something else. sorry.
the function getstring with t allows you to write a text with space then I want to end the input by pressing Space bar as if I am pressing Enter.
gile
  • Marseille, France
« Reply #3 on: February 21, 2017, 06:31:02 AM »
So, which key do you press to write a space in the string... :idiot2:
Coder
« Reply #4 on: February 21, 2017, 06:43:36 AM »
Sorry for the confusion. My bad.
I would like to end the function just if the first input is Space and not in the middle of a string if the user intended to write a long string.
ribarm
  • Marko Ribar, architect
« Reply #5 on: February 21, 2017, 06:50:43 AM »
Perhaps :
(strcat " " (getstring "\nEnter your string like you've typed space firstly : "))
M.R. on Youtube
Coder
« Reply #6 on: February 21, 2017, 09:57:33 AM »
I am sorry for this confusion.
This should be clearer enough.
(setq str (getstring t (strcat "Name of pile :")))
If I try the above codes and hit Enter the variable 'str' would be equal to "" and this is what I trying to do if I hit Space bar I would like to finish the above codes and return the ""
Thank you.
« Reply #7 on: February 21, 2017, 11:01:47 AM »
  1. (defun _fuglyinput (message / gr str)
  2.   (setq str "")
  3.   (while (and (setq gr (grread nil 2)) (/= (cadr gr) 13) (/= str " "))
  4.     (cond ((= 2 (car gr))
  5.       (setq str (cond ((= 8 (cadr gr)) (substr str 1 (1- (strlen str))))
  6.             ((strcat str (chr (cadr gr))))
  7.            )
  8.       )
  9.      )
  10.     )
  11.     (princ (strcat "\r" message str))
  12.   )
  13.   (vl-string-left-trim " " str)
  14. )
  15. (_fuglyinput "Name the pile: ")
« Last Edit: February 21, 2017, 11:48:48 AM by ronjonp »
Coder
« Reply #8 on: February 21, 2017, 11:10:16 AM »
Thank you ronjonp so much for your great help.
I knew that it has something to do with grread but it is above my head.  :yes:
Your function seems to work but I couldn't test it correctly because it continues printing the message to command line without a pause.
Can you please rectify it?
gile
  • Marseille, France
« Reply #9 on: February 21, 2017, 11:12:09 AM »
  1. (defun getstring_T (msg / gr break str)
  2.   (prompt msg)
  3.   (setq str "")
  4.   (while (and (not break) (setq gr (grread 2)))
  5.     (cond
  6.       ((equal gr '(2 13)) ;_ enter
  7.        (setq break T)
  8.       )
  9.       ((equal gr '(2 32)) ;_ space
  10.        (if (= str "")
  11.          (setq break T)
  12.          (setq str (strcat str (princ " ")))
  13.        )
  14.       )
  15.       ((equal gr '(2 8)) ;_ backspace
  16.        (and (/= str "")
  17.             (setq str (substr str 1 (1- (strlen str))))
  18.             (princ (chr 8))
  19.        )
  20.       )
  21.       ((= 2 (car gr)) ;_ any other char
  22.        (setq str (strcat str (princ (chr (cadr gr)))))
  23.       )
  24.     )
  25.   )
  26.   (terpri)
  27.   str
  28. )
« Last Edit: February 21, 2017, 11:18:29 AM by gile »
« Reply #10 on: February 21, 2017, 11:16:40 AM »
Change the "\n" to "\r".
Coder
« Reply #11 on: February 21, 2017, 11:20:21 AM »
  2.   (prompt msg)
  3.   (setq str "")
  5.     (cond
  7.        (setq break T)
  8.       )
  10.        (if (= str "")
  11.          (setq break T)
  13.        )
  14.       )
  18.             (princ (chr 8))
  19.        )
  20.       )
  23.       )
  24.     )
  25.   )
  26.   (terpri)
  27.   str
  28. )
Great work gile.
Thank you so much.
Coder
« Reply #12 on: February 21, 2017, 11:22:06 AM »
Wow that was simple. and great work ronjonp.
Thank you so much.
« Reply #13 on: February 21, 2017, 11:48:09 AM »
Thank you so much.
You're welcome :)
VovKa
  • Ukraine
« Reply #14 on: February 21, 2017, 12:20:12 PM »
gile, i think it's better to change
(princ (chr 8)) to
(princ "\010 \010")
