Hello All,
Been a while since I've been here. Hope everyone's 2017 is off to a good start.
I'm currently having a small issue regarding the use of some old code of mine.
This program essentially allows the user to set active the layer of a user picked entity - pretty damn simple!
However, once the user has picked the desired object/entity, the program does not immediately update the layer control toolbar, only doing so once the user regenerates the drawing. This has been happening since the installation of AutoCAD 2017 on my work PC. No other versions of CAD have had this issue.
I find this behavior strange and something that has never happened before. I can only assume no issue with the code but perhaps a setting in AutoCAD itself. I have tested this code on another users PC using AutoCAD 2017 with no issues whatsoever.
Code is attached for testing.
Any thoughts, fixes, comments are welcome.
Thanks,
Bevan
