Author Topic: Mtext with Space inbetween Characters  (Read 1871 times)
MSTG007
« on: February 20, 2017, 10:50:02 AM »
I know this is an odd one. I am searching "possibly" without lisp where as Mtext is used, a extra space would go in between.
i.e.
THIS IS A TITLE to T H I S  I S  A  T I T L E.
If not, is there a special type of font I could use?
thanks for the help!
Civil3D 2020
Re: Mtext with Space inbetween Characters
« Reply #1 on: February 20, 2017, 11:18:18 AM »
MAYBE THIS
;;  CAB 04/10/2006
;;  Add space(s) to text strings between characters
;; Note that there are problems with format codes especially with mText.
(defun c:textspacer (/ spc ent txt obj spacetext)
  (defun spacetext (txtstring spccnt / spaces newlst)
    (repeat spccnt (setq spaces (cons 32 spaces)))
    (foreach x (vl-string->list txtstring)
      (setq newlst (append newlst (list x) spaces))
    (vl-list->string newlst)
  (initget 6)
  (setq spc (getint "\nHow many spaces do you want to add? 1-5 <1> "))
  (or spc (setq spc 1))
  (if (> spc 5) (setq spc 5))
  (while (setq ent (entsel "\nSelect Text to add spaces to."))
    (setq txt (vla-get-textstring (setq obj (vlax-ename->vla-object (car ent)))))
    (setq txt (spacetext txt spc))
    (vla-put-textstring obj txt)
MSTG007
« Reply #2 on: February 20, 2017, 11:21:11 AM »
LOL.... Thanks CAB... Funny thing is. That is what I have been using to get the job done! Another awesome routine of yours!
Civil3D 2020
« Reply #3 on: February 20, 2017, 11:43:56 AM »
Happy to remind you.  8)
MSTG007
« Reply #4 on: February 20, 2017, 12:16:48 PM »
Did some more researching...
https://forums.autodesk.com/t5/autocad-2007-2008-2009/text-kerning/td-p/2731751
Text Kerning... Now I know what it does.
Civil3D 2020
Cathy
« Reply #5 on: February 28, 2017, 03:21:58 PM »
Why don't you just set the spacing in the editor?
MSTG007
« Reply #6 on: February 28, 2017, 03:24:54 PM »
I think that was genius....  :uglystupid2: Thank you!
Civil3D 2020
ChrisCarlson
« Reply #7 on: March 01, 2017, 08:53:07 AM »
This is the way to go. When you finally switch over to TrueType fonts they will be correctly searchable vs the hard coded space between each letter.
