;; CAB 04/10/2006;; Add space(s) to text strings between characters;; Note that there are problems with format codes especially with mText.(defun c:textspacer (/ spc ent txt obj spacetext) (defun spacetext (txtstring spccnt / spaces newlst) (repeat spccnt (setq spaces (cons 32 spaces))) (foreach x (vl-string->list txtstring) (setq newlst (append newlst (list x) spaces)) ) (vl-list->string newlst) ) (initget 6) (setq spc (getint "\nHow many spaces do you want to add? 1-5 <1> ")) (or spc (setq spc 1)) (if (> spc 5) (setq spc 5)) (while (setq ent (entsel "\nSelect Text to add spaces to.")) (setq txt (vla-get-textstring (setq obj (vlax-ename->vla-object (car ent))))) (setq txt (spacetext txt spc)) (vla-put-textstring obj txt) ) (princ))
Why don't you just set the spacing in the editor?
