Author Topic: Attributes and Fields  (Read 1514 times)
Grrr1337
« on: February 19, 2017, 07:56:34 AM »
Hi everyone,
I have a few copies of the same block and I was trying to link 2 (source and dest) attribute values (from diffrent blockrefs), using field(s):
  1. (setq sAtt (vlax-ename->vla-object (car (nentsel "\nSelect source attribute: "))))
  2. (setq dAtt (vlax-ename->vla-object (car (nentsel "\nSelect dest attribute: "))))
  3. (vla-put-TextString dAtt (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vlax-get sAtt 'ObjectId)) ">%).TextString>%"))
At first it sounded like an easy task, but it didn't work.
Soo... I created another copy of that block, and manually linked (no lisp) his attribute to the source one - and it worked (the handmade one).
Then from the properties of that "handmade" field I got the field textstring which was: " %<\AcObjProp Object(%<\_ObjId 140701967863360>%).TextString>% "
and tried directly assigning the same content (to the 3rd block):
  1.   (vlax-ename->vla-object (car (nentsel "\nSelect dest attribute reference: ")))
  2.   "%<\AcObjProp Object(%<\_ObjId 140701967863360>%).TextString>%"
  3. )
So the above failed.
Then I decided to check if the ObjId should be linked to the attribute reference (see the comments):
  1. %<\AcObjProp Object(%<\_ObjId 140701967863360>%).TextString>% ; extracted from the "handmade" field - that works
  2. _$ (vla-get-ObjectId (vlax-ename->vla-object (car (nentsel "\nSelect source attribute reference:"))))
  3. 42 ; this Id doesn't match the Id from the "handmade" field
  4. "284" ; but the handle from the field's ID matches
  5. _$ (vla-get-Handle (vlax-ename->vla-object (car (nentsel "\nSelect source attribute reference: "))))
  6. "284" ; to the handle of the selected source attribute ref
  7. _$
I have no idea whats wrong  :cry:
Heres the test drawing:
(apply ''((a b c)(a b c))
vevo.bg
Re: Attributes and Fields
« Reply #1 on: February 19, 2017, 08:16:37 AM »
When populating attribute references with field expressions, you usually need to regenerate the drawing or use the UPDATEFIELD command for the field value to be displayed.
Grrr1337
« Reply #2 on: February 19, 2017, 08:26:51 AM »
Thanks for the input, Lee...
However that was not the problem - I did found the solution:
  1. (vla-put-TextString dAtt (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vlax-get sAtt 'ObjectId)) ">%).TextString>%")) ; doesn't work
  1. (vla-put-TextString dAtt (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-ObjectId sAtt)) ">%).TextString>%")) ; works
Seems like vlax-get/vlax-put must be avoided when populating with FIELDS, and use vla-get-*/vla-put-* instead.
vevo.bg
« Reply #3 on: February 19, 2017, 09:03:13 AM »
I'm glad you were able to find the source of the problem. :-)
Be careful when using this technique to obtain the ObjectID when working with 32-bit/64-bit systems, as alternative methods must be used to obtain the ObjectID in order to account for the 32-bit upper limit for signed integers in AutoLISP. You may wish to refer to my LM:objectid function as part of my Area Field to Attribute program as an example of how I account for this.
Grrr1337
« Reply #4 on: February 19, 2017, 10:09:13 AM »
I have some experience with fields, and I keep such subfunction somewhere in my library, although I've forgot to use it.
Thanks again! :)
Hopefully this thread will help for anyone that gets stuck on the same problem.
vevo.bg
