I found this
All relational operators except for the bitwise operators ("&" and "&=") are valid for both real- and integer-valued groups.
The bitwise operators "&" and "&=" are valid only for integer-valued groups. The bitwise AND, "&", is true if ((integer_group & filter) /= 0)—that is, if any of the bits set in the mask are also set in the integer group. The bitwise masked equals, "&=", is true if ((integer_group & filter) = filter)—that is, if all bits set in the mask are also set in the integer_group (other bits might be set in the integer_group but are not checked).
Hope it makes more sense to you than it does to me. -David
