Author Topic: Select the similiar  (Read 4284 times)
Fabricio28
Select the similiar
« on: February 16, 2017, 11:06:44 AM »
Hi all,
I have 2 different MText in my drawing.
- Area
- Lot Number
But this MText is the same layer "-AREA-LOTES".
I'd like to select all MText to Lot Numbers and change to "-NRO-LOTE" layer.
Is it possible?
I was trying to use select the similiar. But I couldn't do that.
Thank in advance
Fabricio
Re: Select the similiar
« Reply #1 on: February 16, 2017, 11:19:25 AM »
  1. (sssetfirst nil (ssget "_x" '((0 . "mtext") (1 . "#,##"))))
Andrea
« Reply #2 on: February 16, 2017, 11:23:01 AM »
(defun c:SSIM (/ circles #count centerp item Mtexts MtextObject vlaitem)
  (setq circles (ssget "_X"
       '((0 . "CIRCLE")
(100 . "AcDbEntity")
(67 . 0)
(410 . "Model")
(8 . "-NRO-LOTE")
(100 . "AcDbCircle")
  (repeat (setq #count (sslength circles))
    (setq item (ssname circles (setq #count (1- #count))))
    (setq centerp (assoc 10 (entget item)))
    (if (setq Mtexts (ssget "_X"
    (list
      '(0 . "MTEXT")
      centerp
(setq MtextObject (ssname Mtexts 0))
(setq vlaitem (vlax-ename->vla-object MTextobject))
(vla-put-layer vlaitem "-NRO-LOTE")
Keep smile...
Fabricio28
« Reply #3 on: February 16, 2017, 11:23:48 AM »
very nice solution my old friend Ron,
Worked like a charm.
Andrea
« Reply #4 on: February 16, 2017, 11:24:47 AM »
+Kudo
Keep smile...
« Reply #5 on: February 16, 2017, 11:27:48 AM »
Thanks guys :)
Fabricio28
« Reply #6 on: February 16, 2017, 11:29:04 AM »
       '((0 . "CIRCLE")
(67 . 0)
(410 . "Model")
(8 . "-NRO-LOTE")
    (list
      '(0 . "MTEXT")
      centerp
Wow :)
Very Nice too Andrea!!
Thank you very much.
Fabricio
Fabricio28
« Reply #7 on: February 16, 2017, 11:34:40 AM »
       '((0 . "CIRCLE")
(67 . 0)
(410 . "Model")
(8 . "-NRO-LOTE")
    (list
      '(0 . "MTEXT")
      centerp
If the circle were in the " -AREA-LOTE" the code isn't working.
My first step is change the circle and the number to "-NRO-LOTE".
But I can select the similar all circle and change the layer as I want to. But couldn't do that to the number.
Will be good if I able to change boths (circle and Number) to "-NRO-LOTE" layer.
« Reply #8 on: February 16, 2017, 11:38:17 AM »
Why don't you make a block with an attribute?
Fabricio28
« Reply #9 on: February 16, 2017, 11:43:22 AM »
Because I've exploded that elements from autocad civil 3D.  :-D
Andrea
« Reply #10 on: February 16, 2017, 11:48:05 AM »
       '((0 . "CIRCLE")
(67 . 0)
(410 . "Model")
(8 . "-NRO-LOTE")
    (list
      '(0 . "MTEXT")
      centerp
why do not mix both code ?
my filtering object is to detext all circle and compare centerpoints to MTEXT who have same centerpoints..
but you can use Ron filtering selection.. :)
or,..
remove the layer filtering..
       '((0 . "CIRCLE")
(67 . 0)
(410 . "Model")
; (8 . "-NRO-LOTE")
Keep smile...
« Reply #11 on: February 16, 2017, 11:51:03 AM »
Because I've exploded that elements from autocad civil 3D.  ;D
>:D  .. this is how I'd do it.
Fabricio28
« Reply #12 on: February 16, 2017, 12:00:17 PM »
Wow!
Do you make a block with the circles and numbers. How could you do that?
Amazing
« Reply #13 on: February 16, 2017, 12:07:37 PM »
Wow!
Amazing
Code  ;)
Fabricio28
« Reply #14 on: February 16, 2017, 12:23:32 PM »
Wow!
Amazing
Code  ;)
I see...
Very impressive  :-)
