CAD Forums > CAD General
Zoom problem
craigr:
I have a campus map that when I do a 'zoom extents', it zooms so far out that I can no longer see the map.
Please take a look at the attached. Hopefully you can find what is out there that is causing this.
Thanks in advance,
craigr
dgorsman:
A couple reasons why this happens here (haven't had a look at that drawing yet):
* XREF not found - marker with saved path/name at insert point
* Vertical content without proper object enabler - again, text marker with "AECblahblahblah" at insert point
* Origin or other marker dropped somewhere out in space
* Blocks with only invisible attributes - these accumulate as people wblock-all and/or insert/explode
craigr:
Most of that is above my head, but I AM trying.
Thanks for the info.
alterego:
another option..
Layers that are switched off rather than frozen
craigr:
All layers are on, etc...
Okay, I give up. I just can't figure anything else. - I am just spinning my wheels and burning hours on this project that I just don't have.
I can't even tell if it is zooming waaay out or if it is zooming waaay in.
I will wait until for tomorrow in hopes that one of you can figure it out. If not, I guess I will have to start over.
Craigr
Navigation
[0] Message Index
[#] Next page
Go to full version
