Author Topic: Programmation inside a drawing..  (Read 4079 times)
Andrea
« on: February 14, 2017, 09:46:44 AM »
is that possible ?
Hi all,..
I've receive a DWG that contain reactor in it !
how this is possible !!? I think this is soooo dangerous..
to be sure,..I've reinstalled AutoCAD from scratch..without any custom settings or prog..
remove all bundle folder from appsexchange....no VBA ObjectEnabler installed..
tested on 5 machine. with diffrent CAD version...
after purging Audit and anything based...
the reactor still active.
so if I use (vlr-remove-all) then the issue is fixed.
however,..This is weird,..so I've made a test and delete all entities in the drawing and purge...
and I've discover that the program is running if a simple specific MTEXT is present in the drawings...
so I check XDATA and remove all...but the program still there...
If I delete the text.....the reactor gone..
If I copy the text and delete the original....the reactor gone.
if I edit text, the reactor still there.
If I edit text and out only a simple space " "...the reactor still there..
so by doing this,...I've an empty drawing containing program in it....this is not only weird...but very dangerous..
so I would like to share the DWG,...but I'm afraid about viruses...because that kind of running function cannot be detected by antivirus I guess..
I open AutoDESK ticket for that,...but they do not seem to be able to help me..
or if you want anyways the DWG for test....please write me PM and i'll send you..
but I'm not responsable of that thing..
any help will be appreciated...
Thank you very much.
Keep smile...
dgorsman
Re: Programmation inside a drawing..
« Reply #1 on: February 14, 2017, 10:10:48 AM »
Isn't the old RTEXT and a few other things handled through persistent reactors?
I haven't played around with persistent reactors much, so I don't know how much of the code stays resident in the drawing.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
Andrea
« Reply #2 on: February 14, 2017, 10:34:21 AM »
no,...simple MTEXT without any field...no Xdata...
Keep smile...
« Reply #3 on: February 14, 2017, 10:54:53 AM »
Hint: It's hiding in ldata.
Andrea
« Reply #4 on: February 14, 2017, 11:02:00 AM »
nope,..no Ldata stored..
Keep smile...
« Reply #5 on: February 14, 2017, 11:17:28 AM »
post the dwg
« Reply #6 on: February 14, 2017, 11:20:29 AM »
Does this help?
(defun _CleanReactors   ( )
    ;;  MP (distilled from code authored by Luis Esquivel)
    ;;  See post: http://www.theswamp.org/index.php?topic=6870.msg112068#msg112068
    (mapcar
        (function
            (lambda (reactor)
                    (   (and
                            (equal (vlr-type reactor) :vlr-object-reactor)
                            (or
                                (vl-some 'vlax-erased-p (vlr-owners reactor))
                                (null (vlr-owners reactor))
                        (foreach owner (vlr-owners reactor)
                            (vlr-owner-remove reactor owner)
                        (vlr-data-set reactor nil)
                        (vlr-pers-release reactor)
                    (   (and
                            (vlr-added-p reactor)
                            (not (equal (vlr-type reactor) :vlr-object-reactor))
                            (or
                                (vl-some 'vlax-erased-p (vlr-data reactor))
                                (not (vlr-data reactor))
        (vlr-pers-list)
Andrea
« Reply #7 on: February 14, 2017, 11:28:26 AM »
Does this help?
    (mapcar
        (function
            (lambda (reactor)
                    (   (and
                            (or
                    (   (and
                            (or
        (vlr-pers-list)
no.... :|
Keep smile...
« Reply #8 on: February 14, 2017, 11:36:55 AM »
See reply #6.
Andrea
« Reply #9 on: February 14, 2017, 11:47:37 AM »
Keep smile...
« Reply #10 on: February 14, 2017, 11:50:08 AM »
If you really want help post the drawing.
Stefan
« Reply #11 on: February 14, 2017, 11:54:07 AM »
So, what exactly is running? A lisp, a code, something else?
And when? At the opening? When you try to modify this Mtext?
Andrea
« Reply #12 on: February 14, 2017, 11:56:28 AM »
post the dwg
Ok,,..there is more info...
each time the text is modified, or the drawing SAVED ...the reactor run.
and look at a function require 3 arguments..
fonction looking at:
TESTDEMODIFICATIONRECTANGLE
so I'Ve created this function
(defun TESTDEMODIFICATIONRECTANGLE (a b c)(alert "test"))
and then, test the drawing manipulation.
please be careful because I don'T know if there is any other reactor or function running.
I've discovered that because of error message when saving the DWG.
Thanks for the help.
« Last Edit: February 14, 2017, 12:03:17 PM by Andrea »
Keep smile...
roy_043
  • BricsCAD 18
« Reply #13 on: February 14, 2017, 12:25:21 PM »
(namedobjdict) > "VL-REACTORS" > "$DOC$" (is a "VLO-VL" entity... so MP's first hint seem to be correct)
« Reply #14 on: February 14, 2017, 12:37:09 PM »
Some more info:
  1. _$
  2. ((-1 . <Entity name: 1a98f370dc0>)
  3.   (0 . "VLO-VL")
  4.   (5 . "281E4")
  5.   (102 . "{ACAD_REACTORS")
  6.   (330 . <Entity name: 1a98f362e90>)
  7.   (102 . "}")
  8.   (330 . <Entity name: 1a98f362e90>)
  9.   (100 . "vlo_VL")
  10.   (90 . -64512)
  11.   (91 . 142)
  12.   (92 . 1)
  13.   (340 . <Entity name: 1a98f365bc0>)
  14.   (300
  15.     .
  16.     "((&VLO-C Object-Reactor ((:VLR-modified . \"TESTDEMODIFICATIONRECTANGLE\") (:VLR-erased . \"ENLEVEREACT\")) ((&VLO-A . 0)) (\"17F09\" \"17F0A\") 0 T))"
  17.   )
  18. )
  19. _$
