post the dwg
Ok,,..there is more info...
each time the text is modified, or the drawing SAVED ...the reactor run.
and look at a function require 3 arguments..
fonction looking at:
TESTDEMODIFICATIONRECTANGLE
so I'Ve created this function
(defun TESTDEMODIFICATIONRECTANGLE (a b c)(alert "test"))
and then, test the drawing manipulation.
please be careful because I don'T know if there is any other reactor or function running.
I've discovered that because of error message when saving the DWG.
Thanks for the help.
