Author Topic: Calculate the coordinates of the point  (Read 4706 times)
Hugo
Re: Calculate the coordinates of the point
« Reply #15 on: February 10, 2017, 01:15:15 AM »
Yes for rectangles, lines and poly is with me.
Then I understand something wrong?  :-(
For X-Ref it is unfortunately not?   :-(
Ja für Rechtecke, Linien und Poly geht es bei mir.
Dann verstehe ich was falsch ?
Für X-Ref geht es leider nicht ?
« Last Edit: February 10, 2017, 01:20:42 AM by Hugo »
andy_lee
« Reply #16 on: February 10, 2017, 01:28:41 AM »
The result only rectangle is right ! because the angle is 90
you can draw 2 line . the angle is not 90. test again
andy.
Best regards.
Hugo
« Reply #17 on: February 10, 2017, 01:36:52 AM »
Hier
andy_lee
« Reply #18 on: February 10, 2017, 01:42:48 AM »
andy.
Best regards.
Hugo
« Reply #19 on: February 10, 2017, 01:47:25 AM »
OK now I understand.
This is not true.   :embarrassed:
It's Alive!
  • Retired
  • AKA Daniel
« Reply #20 on: February 10, 2017, 02:10:16 AM »
If you consider a vector has a distance and a direction, the direcrion can be expressed by an X distance and a Y distance,
and the hypotenuse of the triangle formed is the vector distance.
A unit vector has the triangle hypotenuse reduced to one unit with the X and Y distances modified accordingly.
This may help :
https://www.khanacademy.org/math/precalculus/vectors-precalc/unit-vectors/v/unit-vector-intro
unit vectors have little hats
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #21 on: February 10, 2017, 02:43:53 AM »
Yep ... a party hat.
but just to show they are not all frivolous ...
Consider a unit vector with a direction of 30 degrees.
cos(30) is 0.8660 which is the x offset
sin(30) is 0.50 which is the Y offset.
similarly cos(45) and sin(45) are both 0,7071  which is the the x an Y offset from the startpoint.
My old math master used to say something like " the universe is made up of circles and triangles"
... I've since come to understand that he wasn't really joking.
Called Kerry in my other life
I live at UTC + 13.00
andy_lee
« Reply #22 on: February 10, 2017, 04:12:53 AM »
Still can't understand. my math is so bad.
Math master and Lisp master .please give a fish.
@Lee Mac @ribarm @roy_043  ....
andy.
Best regards.
kdub_nz
  • SuperMod
« Reply #23 on: February 10, 2017, 04:20:21 AM »
I can't understand No.3. what is unit vector?
You're welcome.
... my math is so bad.
Well, do something about it.
I'm outa here.
andy_lee
« Reply #24 on: February 10, 2017, 05:14:47 AM »
This I do:
https://www.theswamp.org/index.php?topic=52652.msg575395#msg575395
I want use Lee's method. but I can't understand.
andy.
Best regards.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #25 on: February 10, 2017, 07:20:49 AM »
Joking aside, thanks for the link  8-)
