Author Topic: Calculate the coordinates of the point  (Read 4725 times)
andy_lee
« on: February 08, 2017, 05:46:07 AM »
Dear All
Known  offset value D1 and D2 , Pick 2 line , Calculate the coordinates of the point "P"
Line1 and Line 2 must have a intespoint . if not inters , prompt
Line1 and Line2 maybe is A portion of a polyline.
(setq *D1* 10)
(setq *D2* 15)
(setq L1 (entsel "\n>>>Pick First line :"))
(setq L2 (entsel "\n>>>Pick Second line :"))
Thanks for any help !
andy.
Best regards.
andy_lee
Re: Calculate the coordinates of the point
« Reply #1 on: February 08, 2017, 06:02:22 AM »
Oh! Post wrong place , Administrator , Please help me  move  it to “AutoLISP (Vanilla / Visual)”  ,Thank you !
andy.
Best regards.
« Reply #2 on: February 08, 2017, 12:45:06 PM »
  • Obtain the endpoints of each selected line
  • Calculate the line intersection point (using inters with the end points)
  • Calculate a unit vector from the intersection point to the opposite end point of each line
  • Scale each vector by the require distance (d1 & d2)
  • Add the vectors to obtain the required point.
andy_lee
« Reply #3 on: February 08, 2017, 09:04:03 PM »
Hi
Lee  Thank you for help!
Sometime the result is wrong. why?
(setq *D1* 10)
(setq *D2* 15)
(setq L1(entsel "\n>>>Pick First Line:"))
(setq L2(entsel "\n>>>Pick Second Line:"))
(setq pt1(vlax-curve-getClosestPointTo(vlax-ename->vla-object(car L1))(cadr L1)nil))
(setq pt2(vlax-curve-getClosestPointTo(vlax-ename->vla-object(car L2))(cadr L2)nil))
(setq interpoint
      (inters
          pt1(polar pt1(+(angle(cadr L1)pt1)(* 0.5 pi)) 5.0)
          pt2(polar pt2(+(angle(cadr L2)pt2)(* 0.5 pi)) 5.0)
          nil
(setq pt1-1 (polar pt1(angle interpoint pt2) *D1*))
(setq pt2-1 (polar pt2(angle interpoint pt1) *D2*))
(setq p
      (inters
           pt1-1(polar pt1-1(+ (angle pt1-1 pt1) (* 0.5 pi)) 5)
           pt2-1(polar pt2-1(+ (angle pt2-1 pt2) (* 0.5 pi)) 5)
           nil
andy.
Best regards.
Hugo
« Reply #4 on: February 09, 2017, 12:59:36 AM »
At with it goes.
Bei mit geht es.
(setq *D1* 10)
(setq *D2* 15)
(setq interpoint
      (inters
          nil
(setq p
      (inters
           nil
(defun Circle (cen rad)
  (entmakex (list (cons 0 "CIRCLE")
                  (cons 10 cen)
                  (cons 40 rad))))
(Circle p 1)
Hugo
« Reply #5 on: February 09, 2017, 08:04:17 AM »
When I click on a line in the X-Ref klick I get also an error message   :-o
; error: bad argument value: AcDbCurve 42
Hugo
« Reply #6 on: February 09, 2017, 12:30:03 PM »
Can wehel help you the lines also in an X-Ref can click.
"Nentsel" does not go unfortunately.    :-o
Thank you   :-)
Kann wehr Helfen das man die Linien auch in einer X-Ref anklicken kann.
"nentsel"  geht leider nicht.
Danke
andy_lee
« Reply #7 on: February 09, 2017, 08:17:08 PM »
At with it goes.
Bei mit geht es.
(setq *D1* 10)
(setq *D2* 15)
(setq interpoint
      (inters
          nil
(setq p
      (inters
           nil
                  (cons 10 cen)
                  (cons 40 rad))))
(Circle p 1)
Hello
I can't see any change,  you just add a test function?
andy.
Best regards.
andy_lee
« Reply #8 on: February 09, 2017, 09:58:02 PM »
I can't understand No.3. what is unit vector?
andy.
Best regards.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #9 on: February 10, 2017, 12:02:57 AM »
If you consider a vector has a distance and a direction, the direcrion can be expressed by an X distance and a Y distance,
and the hypotenuse of the triangle formed is the vector distance.
A unit vector has the triangle hypotenuse reduced to one unit with the X and Y distances modified accordingly.
This may help :
https://www.khanacademy.org/math/precalculus/vectors-precalc/unit-vectors/v/unit-vector-intro
Called Kerry in my other life
I live at UTC + 13.00
Hugo
« Reply #10 on: February 10, 2017, 12:22:09 AM »
Here my test
(defun c:Test ( /)
  (setq *D1* (getreal "\nAbstand von Wand D1 eingeben: "))
  (setq *D2* (getreal "\nAbstand von Wand D2 eingeben: "))
;;(setq *D1* 10)
;;(setq *D2* 15)
(setq interpoint
      (inters
          nil
(setq p
      (inters
           nil
(Circle p 10)
);defun
                  (cons 10 cen)
                  (cons 40 rad))))
Hugo
« Reply #11 on: February 10, 2017, 12:23:27 AM »
Q kdub    :? :? :?
kdub_nz
  • SuperMod
« Reply #12 on: February 10, 2017, 12:32:55 AM »
Q kdub    :? :? :?
You have a problem with my response Hugo ??
Hugo
« Reply #13 on: February 10, 2017, 01:06:05 AM »
Yeah I'm too high for me   :cry: :cry: :cry:
Ja ich das ist zu hoch für mich
andy_lee
« Reply #14 on: February 10, 2017, 01:07:33 AM »
Here my test
(defun c:Test ( /)
;;(setq *D1* 10)
;;(setq *D2* 15)
(setq interpoint
      (inters
          nil
(setq p
      (inters
           nil
(Circle p 10)
);defun
                  (cons 10 cen)
                  (cons 40 rad))))
Hi
I can't see any change again,This code applies only to the rectangle
you can draw 2 line test.
andy.
Best regards.
