Author Topic: Invoke VLIDE via Lisp?  (Read 2646 times)
Peter2
« on: February 07, 2017, 11:25:25 AM »
I try to start VLIDE via Lisp (because I want to use vlisp-compile, but failed:
  1. Befehl: (vl-cmdf "vlide")
  2. Unbekannter Befehl "VLIDE". Drücken Sie F1-Taste für Hilfe.
  3. T
  4. --> unknown command
  5.
  6. Befehl: (command "vlide")
  7. Unbekannter Befehl "VLIDE". Drücken Sie F1-Taste für Hilfe.
  8. nil
  9. --> unknown command
  10.
  11. Befehl: (dcl-SendString "vlide ")
  12. T
  13.
  14. --> Command from OpenDCL. It opens VLIDE, but the synchronization between opening VLIDE and continuing Lisp-code creates an error?
  15.
Can it be solved?
BTW: When I start VLIDE manually, then the lisp with vlisp-compile works fine....
Thanks and regards
« Last Edit: February 07, 2017, 12:58:02 PM by Peter2 »
Peter
BricsCAD V23
rkmcswain
Re: Invoke VLIDE via Lisp?
« Reply #1 on: February 07, 2017, 11:33:32 AM »
This works for me.
(defun C:foo () (c:vlide)(princ))
Peter2
« Reply #2 on: February 07, 2017, 01:01:49 PM »
Thanks - works fine.
(Additional info for readers:
- The command brings VLIDE to foreground. An additional click (e.g. minmize) continues the lisp.
- For usage of vlisp-compile it is not necessary that VLIDE is always open, but it has to be invoked at least one time ..)
Peter
BricsCAD V23
snownut2
  • Bricscad 22 Ultimate
« Reply #3 on: February 07, 2017, 02:52:13 PM »
Or this  (c:vlide T) starts vlide minimized....
« Last Edit: February 07, 2017, 03:12:56 PM by snownut2 »
Peter2
« Reply #4 on: February 08, 2017, 03:11:34 AM »
Great - thanks.
(Where did you get the information from? I checked F1 in VLIDE - and got the AutoCAD-Help starting page; checked the V-functions-reference ... - no info about "c:vlide T" ... )
Peter
BricsCAD V23
BIGAL
  • 40 + years of using Autocad
« Reply #5 on: February 18, 2017, 10:20:48 PM »
You can do a lisp compile directly without invoking vl-ide. A quick google help from Autodesk
Examples
Assuming that yinyang.lsp resides in a directory that is in the AutoCAD support file search path, the following command compiles this program:
(vlisp-compile 'st "yinyang.lsp")
T
The output file is named yinyang.fas and resides in the same directory as the source file.
The following command compiles yinyang.lsp and names the output file GoodKarma.fas:
(vlisp-compile 'st "yinyang.lsp" "GoodKarma.fas")
Peter2
« Reply #6 on: February 20, 2017, 04:47:52 AM »
You can do a lisp compile directly without invoking vl-ide. ...
For me it works only as described above: VLIDE has to be invoked at least once (and can be closed again), then the command will do its job.
On a freshly started AutoCAD-session I get
Befehl: (vlisp-compile 'st "x.lsp")
; Fehler: no function definition: VLISP-COMPILE
when VLIDE was not started before.
Peter
BricsCAD V23
marcoheuer
  • Mosquito
« Reply #7 on: February 20, 2017, 09:40:25 AM »
from acad dev help file:
Note: The Visual LISP IDE must be open in order for vlisp-compile to work.
best regards
marco
Peter2
« Reply #8 on: February 21, 2017, 03:09:25 AM »
Any idea how to close VLIDE via Lisp? The following code does nothing or opens it
  1. Befehl: (c:vlide T)
  2. Befehl: (c:vlide nil)
  3. Befehl: (c:vlide close)
And here are no solutions either:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/close-vlide/td-p/2502632
Seem to be impossible...
« Last Edit: February 21, 2017, 03:32:18 AM by Peter2 »
Peter
BricsCAD V23
snownut2
« Reply #9 on: February 21, 2017, 08:17:52 AM »
Not that I'm aware of.
