Just had to ask this. If I have a lot of blocks that have Mleaders with MText and there is some text that is not ByLayer (Same with Dimensions). How can I select several blocks and it make everything bylayer?
I have a few routines that can make block to Layer 0 and Bylayer, but the overwritten color of the mleader text and dim still remain.
I have also tried the setbylayer command, with no luck,
Thanks for any feedback!
