This version working perfect with Text and Mtext.But with block I am facing some troubles the code draw the line but not in correct location.
The coordinate data obtained from the block definition will need to be transformed relative to each block reference which references the definition; for this, you will require a function similar to gile's RefGeom function.
Can you please post the drawing you are using.I'll have a look tonight when I get home if no-one else pops in first.
