I use model space dims, but now I am having to allow for paperspace dims.
Using BeginDoubleClick(object sender, BeginDoubleClickEventArgs e)
db.Dimstyle = dimId;
db.SetDimstyleData(tr.GetObject(dimId, OpenMode.ForRead) as DimStyleTableRecord);
the dim control changes immediately. When doing the same thing with end command "LAYOUT_CONTROL"
or SysvarChanged(object sender,Autodesk.AutoCAD.ApplicationServices.SystemVariableChangedEventArgs e)
using Tilemode the dims change correctly but the Dim Style control doesn't update.
Anyone know how to force the dim Style Control? (I couldn't find it in the reg)
