Author Topic: Image from resources (Embedded in .resx)  (Read 2099 times)
djee
« on: January 23, 2017, 02:59:42 PM »
I'm trying to use an image from my resources (Embedded in .resx) for one of my WPF button. Nothing is working... I can see the image in my designer but not when executing... The image resource is of type Bitmap.  I've tried lots of different scenario & can't get anything going. Anybody has experience using images from resources? :crazy2:
NOT working:
Dim myAssembly As System.Reflection.Assembly = System.Reflection.Assembly.GetExecutingAssembly()
Dim myStream As Stream = myAssembly.GetManifestResourceStream("FreezeOn.png")
Dim image As New Bitmap(myStream)
my XAML
  <Button Name="ScanFile">
                <StackPanel>
                    <Image Name="myExitImage"  Source="pack://siteoforigin:,,,/Resources/FreezeOn.png"/>
                </StackPanel>
            </Button>
« Last Edit: January 23, 2017, 03:38:42 PM by djee »
Bobby C. Jones
Re: Image from resources (Embedded in .resx)
« Reply #1 on: January 23, 2017, 03:20:49 PM »
I don't have many images saved as resources, but I did find this one.
Bobby C. Jones
djee
« Reply #2 on: January 23, 2017, 03:34:50 PM »
Is the persistence setting of your image set to: Embedded in .resx? I`m guessing everything is fine on your side of thing (you can see the image)? If you copy your app to another directory, do you still see the resource image ?
Bobby C. Jones
« Reply #3 on: January 23, 2017, 04:20:06 PM »
It's not listed in the .resx file, just set as Resource for the build action.
Bobby C. Jones
Bobby C. Jones
« Reply #4 on: January 23, 2017, 04:20:53 PM »
Sorry, yes and yes.
Bobby C. Jones
djee
« Reply #5 on: January 23, 2017, 05:18:18 PM »
Thanks to the image you've posted, I just saw the BUILD ACTION comboBox menu... As you've mention, I just changed the build action to ''Ressource'' & all is fine... I won't tell you how much time I lost trying to figure this one out...  :whistling:
Thanks a bunch!
