Author Topic: Print to grey scales  (Read 2083 times)
Andrea
« on: January 13, 2017, 09:54:33 AM »
Hi all,..
Anyone know how to use DWG to PDF.pc3 to print Drawing contain colored image in grey scales ?
I can't find the way...:(
Thank you.
Keep smile...
ChrisCarlson
Re: Print to grey scales
« Reply #1 on: January 13, 2017, 11:48:48 AM »
Plotting is based on a plot style, what are your plot style settings for each applicable color?
Andrea
« Reply #2 on: January 13, 2017, 02:14:15 PM »
a drawing contain colored images...
even if ctb monocrhome ...the image still in color when making PDF with DWGtoPDF.pc3 file..
so in some tools,..like PDFcreator or PDF995,...it is possible to convert colored image in greyscale..
but DWGtoPDF.pc3 do not seem to allow that.
(see pic)
Keep smile...
Rob...
« Reply #3 on: January 13, 2017, 04:23:31 PM »
I tried to find an answer to this a while back. No matter what I tried, it did not work. I ended up scanning the hard copy to PDF.
CAD Tech
ChrisCarlson
« Reply #4 on: January 16, 2017, 08:05:08 AM »
DWF to PDF.pc3 is the plotter file, colors are determined by the plot style .ctb. Choose a color from your drawing and cross reference it with your plot style.
rkmcswain
« Reply #5 on: January 16, 2017, 08:53:29 AM »
Quote from: Master_Shake
Read Post 3 Reply #2 again. OP already addressed this.
ChrisCarlson
« Reply #6 on: January 16, 2017, 09:58:36 AM »
If the OP is in regards to attached images which have color, then yes they will plot in color. AutoCAD does not have photo editing capabilities, nor do I forsee them incorporating it.  The only real solution is to edit the photos prior to attachment.
rkmcswain
« Reply #7 on: January 16, 2017, 10:08:14 AM »
I believe what OP wants is a driver based method of printing in grayscale, like you can do in the DWF driver.
