Author Topic: Block or Xref to a Selected State?  (Read 1424 times)
MSTG007
« on: January 09, 2017, 08:23:35 AM »
Got another dumb question. Typically when you select and xref or block it highlights itself. You hit escape to run another command and it goes away. Is there a way that you can toggle the highlight mode on an xref or block so it shows that way until you turn it off? This kinda ties back with Comparing Objects that are on top of each other to see if there are difference?
Thanks for the ideas!
Civil3D 2020
lamarn
Re: Block or Xref to a Selected State?
« Reply #1 on: January 09, 2017, 10:05:13 AM »
I think there is not some kind of toggle to do that.
Maybe you can use the 'group' command to specify some kinf of selection.
But i normalyy use 'xref'overlay with transparency and different colors to look for differences in files...
tedg
« Reply #2 on: January 10, 2017, 08:29:00 AM »
Just a thought..
when Pickadd = 2 you can use the "Select" command and it keeps the item highlighted (selected) for the next command.
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
MSTG007
« Reply #3 on: January 10, 2017, 08:49:10 AM »
Now, that is interesting! Thanks for finding that out.
Civil3D 2020
