Author Topic: Wanted - "Updater" software, standalone, open source  (Read 1992 times)
Peter2
« on: January 06, 2017, 10:13:26 AM »
Who can recommend an "Updater-software" for Lisp / OpenDCL / DosLIB apps which should to what an Updater does:
  • The users starts the software / app
  • It checks the PC and a web-server
  • It does the update, if necessary
It should be Standalone and open-source.
I'm sure there a some apps for it, but also good experience with AutoCAD / Lisp would be fine.
Have a fine weekend!
Peter
BricsCAD V23
BIGAL
  • 40 + years of using Autocad
Re: Wanted - "Updater" software, standalone, open source
« Reply #1 on: January 08, 2017, 04:25:16 PM »
I am basing this on a Autocad solution, you can open a remote server and do normal file stuff so you could check versions on pc and download / replace. I will try to find an example for you, it was posted at Cadtutor as the poster wanted to do the same thing.
BIGAL
Peter2
« Reply #3 on: January 09, 2017, 06:08:34 AM »
@BIGAL
thanks, I will check it.
Peter
BricsCAD V23
Peter2
« Reply #4 on: January 10, 2017, 01:57:21 PM »
Hi @BIGAL
the software works fine, but the code (see entire code in the link above)
(foreach byte tbl
    (vlax-invoke fic 'write (vl-list->string (list byte))) ; Bits to String
is rather slow. It is not really urgent, but any ideas to increase the speed?
Thanks and regards
Peter
Peter
BricsCAD V23
roy_043
  • BricsCAD 18
« Reply #5 on: January 10, 2017, 02:35:28 PM »
What is the reason for not using vla-getremotefile?
Peter2
« Reply #6 on: January 10, 2017, 02:46:40 PM »
No specific reason - I started with the linked code, this area is new for me ...
Every good / better / faster solution is appreciated.
(Interesting: there are no postings with vla-getremotefile here, except of this thread)
Peter
BricsCAD V23
Peter2
« Reply #8 on: January 10, 2017, 04:39:55 PM »
Thanks Lee, for the links. There are some fine solutions  :-)
Peter
BricsCAD V23
Peter2
« Reply #9 on: January 13, 2017, 11:58:02 AM »
Hi
at the end I used this (See other topic for my problems with other solutions):
https://www.theswamp.org/index.php?topic=33750.msg391249#msg391249
Peter
BricsCAD V23
