Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Check if ename or object
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Check if ename or object (Read 1145 times)
mailmaverick
Bull Frog
on:
December 29, 2016, 03:22:31 AM »
Is it possible to check if a variable is an entity-name or object ?
Logged
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Re: Check if ename or object
Reply #1 on:
December 29, 2016, 03:48:16 AM »
Yes
Logged
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #2 on:
December 29, 2016, 04:01:15 AM »
Have a play ...
Code - Auto/Visual Lisp:
[Select]
setq
acadObj
vlax-get-acad-object
;;-> #<VLA-OBJECT IAcadApplication 00007ff7bf137538>
type
acadObj
;;-> VLA-OBJECT
type
acadObj
VLA-OBJECT
setq
ename
cdar
entget
entlast
;;-><Entity name: 158e8ba9460>
type
ename
;;-> ENAME
type
ename
'ENAME
Logged
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #3 on:
December 29, 2016, 04:11:55 AM »
Realised I had these in my Library
May help you ..
[Select]
;; (KDUB:emptystring-p "1") ->nil
;; (KDUB:emptystring-p "") ->T
;; (KDUB:emptystring-p " ") ->T
;; (KDUB:notemptystring-p "x") -> T
;; (KDUB:notemptystring-p "") -> nil
;; (KDUB:notemptystring-p " ") -> nil
;; (KDUB:validstring-p "x") -> T
;; (KDUB:validstring-p "") -> nil
;; (KDUB:validstring-p " ") -> T
defun
kdub:string
p
arg
type
arg
'str
defun
kdub:validstring
p
arg
and
type
arg
'str
0
strlen
arg
defun
kdub:emptystring
p
arg
and
type
arg
'str
0
strlen
vl-string-trim
arg
defun
kdub:notEmptystring
p
arg
and
type
arg
'str
0
strlen
vl-string-trim
arg
defun
kdub:real
p
arg
equal
type
arg
'real
defun
kdub:integer
p
arg
equal
type
arg
'int
defun
kdub:vlaobject
p
arg
equal
type
arg
vla-object
defun
kdub:ename
p
arg
equal
type
arg
'ename
defun
kdub:variant
p
arg
equal
type
arg
variant
Logged
Grrr1337
Swamp Rat
WWW
Reply #4 on:
December 29, 2016, 06:18:52 AM »
Or if you have the handle, then you could simply convert it to an ename or vla-object:
[Select]
_$
setq
handle
cdr
assoc
5
entget
car
entsel
"24B"
_$
handent
handle
Entity name: 7ff662504cb0
_$
vla-HandleToObject
vla-get-ActiveDocument
handle
VLA-OBJECT
IAcadLWPolyline 000000623f71d378
_$
Logged
(apply ''((a b c)(a b c))
vevo.bg
mailmaverick
Bull Frog
Reply #5 on:
December 29, 2016, 11:36:06 PM »
Thanks to all.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
