I'm confused between "TextAlignmentPoint" property and "InsertionPoint" property for text.
I have read the AutoCad Documentation help also but still confused.
For TextAlignmentPoint, it says :-
Text: This property will be reset to 0, 0, 0 and will become read-only when the Alignment property is set to acAlignmentLeft. To position text whose justification is left, fit, or aligned, use the InsertionPoint property.
For InertionPoint, it says :
MText: Specifies the location for a corner of the text boundary. Use the AttachmentPoint property to specify which corner of the text boundary is to be positioned at this insertion point.
Text: This property is read-only except for text whose Alignment property is set to acAlignmentLeft, acAlignmentAligned, or acAlignmentFit. To position text whose justification is other than left, aligned, or fit, use the TextAlignmentPoint property.
If anybody can understand it, please explain.
