Author Topic: Create pdf file-Sheet Set Managem  (Read 2733 times)
Fabricio28
« on: December 06, 2016, 07:31:12 AM »
Hi guys,
How are you?
My project has 6 layouts. I've created a sheet set and I'm trying to plot to PDF.
But I couldn't do that and I don't know why.
Anybody could help me, please?
Re: Create pdf file-Sheet Set Managem
« Reply #1 on: December 06, 2016, 07:51:13 AM »
It looks like it worked. Unless a "student" version does not have that option.
Fabricio28
« Reply #2 on: December 06, 2016, 07:58:44 AM »
Hi Mark
It isn't working properly.
I can plot each one of them. But I can't plot all of them in just one pdf file.
ChrisCarlson
« Reply #3 on: December 06, 2016, 08:10:05 AM »
Plot to PDF uses your current page setups, first check your page setup for each layout tab. Next, always save prior to publishing.
Fabricio28
« Reply #4 on: December 06, 2016, 08:16:19 AM »
I've already checked all my page setup.
When I finished my plot, that message appear.
But there isn't any error.
« Last Edit: December 06, 2016, 08:25:42 AM by FABRICIO28 »
ChrisCarlson
« Reply #5 on: December 06, 2016, 08:22:34 AM »
Did you click the link? The log will tell you everything you need to know.
Fabricio28
« Reply #6 on: December 06, 2016, 08:26:17 AM »
Yes I did. No error at the log.
« Last Edit: December 06, 2016, 08:38:07 AM by FABRICIO28 »
ChrisCarlson
« Reply #7 on: December 06, 2016, 08:40:35 AM »
Look in your settings and turn on plot logging.
ChrisCarlson
« Reply #8 on: December 06, 2016, 08:42:10 AM »
Options attached
Fabricio28
« Reply #9 on: December 06, 2016, 08:49:15 AM »
ChrisCarlson
« Reply #10 on: December 06, 2016, 09:19:14 AM »
Just so the community can benefit, what was the error?
Fabricio28
« Reply #11 on: December 06, 2016, 10:37:12 AM »
I've set the same configuration in your computer.
And I worked fine.  :-D
