Author Topic: How can I Transform Cordinate System  (Read 1601 times)
sigster
« on: December 04, 2016, 09:36:07 AM »
Hi
I use this code to Transform Cordinate System
How can I Transform all object in open drawing just loop through all object and Transform
   <CommandMethod("CONVERT_TO")> _
        Sub Convert_to()
            Dim path_File As String = OpenFile()
            If (path_File = "") Then
                Exit Sub
            Else
                Dim editor As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
                Dim Attach_file As String = path_File
                Dim Project_M As ProjectModel = HostMapApplicationServices.Application.ActiveProject
                Project_M.Options.MarkObjectsForEditingWithoutPrompting = True
                Dim keywordOptions = New PromptKeywordOptions(vbLf & "Select [LL84/ISN93]: ", "LL84 ISN93")
                keywordOptions.Keywords.[Default] = "ISN93"
                Dim keywordResult As PromptResult = editor.GetKeywords(keywordOptions)
                If keywordResult.Status = PromptStatus.OK Then
                    If keywordResult.StringResult = "LL84" Then
                        Project_M.Projection = "LL84"
                    End If
                ElseIf keywordResult.StringResult = "ISN93" Then
                    Project_M.Projection = "ISN93.IcelandGrid"
                End If
                Dim dwgset As DrawingSet = Project_M.DrawingSet
                dwgset.AttachDrawing(Attach_file)
                Dim Query_Model As QueryModel = Project_M.CurQuery
                Query_Model.Mode = QueryType.QueryDraw
                Query_Model.Clear()
                Dim qryRoot As QueryBranch = QueryBranch.Create()
                Dim locationcondition As New LocationCondition()
                locationcondition.LocationType = Autodesk.Gis.Map.Constants.LocationType.LocationCrossing
                locationcondition.Boundary = AllBoundary.Create()
                qryRoot.AppendOperand(locationcondition)
                Query_Model.Define(qryRoot)
                Dim queriedobjids As ObjectIdCollection = Query_Model.Execute(dwgset)
                Query_Model.Clear()
                dwgset.DetachDrawing(Attach_file)
                Dim acadApp As Object = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
                acadApp.ZoomExtents()
            End If
        End Sub
        Public Function OpenFile() As String
            Dim strFileName = ""
            Dim fileDialogBox As New OpenFileDialog()
            fileDialogBox.Filter = "Autocad Drawing|*.dwg"
            fileDialogBox.FilterIndex = 3
            fileDialogBox.InitialDirectory = Environment.GetFolderPath(Environment.SpecialFolder.Personal)
            If (fileDialogBox.ShowDialog() = DialogResult.OK) Then
                strFileName = fileDialogBox.FileName
            End If
            Return strFileName
        End Function
