Author Topic: Diesel expression doesn't update  (Read 1706 times)
dubb
« on: November 23, 2016, 12:28:01 PM »
I am trying to obtain the substring of the first two characters of a layout name using a diesel expression. When I change the name of the layout it doesn't change. The text becomes static. Whats going on here?
Layout name "01-Title Sheet"
Field Text: $(substr,%<\AcVar ctab>%,1,2)
Result: 01
Layout name changed: "02-Title Sheet"
Result: 01
roy_043
  • BricsCAD 18
Re: Diesel expression doesn't update
« Reply #1 on: November 23, 2016, 12:44:38 PM »
Diesel expression:
$(substr,$(getvar,CTAB),1,2)
ChrisCarlson
« Reply #2 on: November 23, 2016, 12:57:47 PM »
I don't believe Diesel expressions are automatic, they must be refreshed.
roy_043
  • BricsCAD 18
« Reply #3 on: November 24, 2016, 04:07:12 AM »
This applies to all fields.
dubb
« Reply #4 on: November 28, 2016, 03:54:19 PM »
Thanks!
I guess by using
%<\AcVar ctab>% it became static?
