Author Topic: What is simplest way to make custom linetypes?  (Read 2131 times)
nobody
  • .net stuff
« on: November 22, 2016, 12:30:47 AM »
What is simplest way to make custom linetypes?  Are there better methods than manually creating/entering info into a .lin file?
Atook
  • AKA Tim
Re: What is simplest way to make custom linetypes?
« Reply #1 on: November 22, 2016, 12:34:59 AM »
nobody
  • .net stuff
« Reply #2 on: November 22, 2016, 02:27:56 AM »
Thank you, will give that a shot   :-D
« Reply #3 on: November 22, 2016, 10:21:50 AM »
HERE is the latest version of that code ... quite a few more options.  8)
roy_043
  • BricsCAD 18
« Reply #4 on: November 22, 2016, 04:18:57 PM »
@ronjonp:
Just a hint: Reading your code I see that you are using X=0 and unequal text gaps to position the text. This works fine for straight line segments, but not for long texts in tight curves.
« Reply #5 on: November 22, 2016, 05:33:29 PM »
@ronjonp:
How would you solve this ? I've never gotten long text to look pretty on curves.
roy_043
  • BricsCAD 18
« Reply #6 on: November 23, 2016, 05:10:19 AM »
You are right: long texts do not look good on curves. But using equal text gaps is better.
Note that some people on the Autodesk team do not seem to know this either. :-D
*BAD, Gaps not equal
A,10,-1,["TestTestTest",STANDARD,S=2,R=0,X=0,Y=-],-17
*BETTER, Gaps equal
A,10,-9,["TestTestTest",STANDARD,S=2,R=0,X=-8,Y=-],-9
« Last Edit: November 23, 2016, 05:14:30 AM by roy_043 »
« Reply #7 on: November 23, 2016, 04:11:18 PM »
Thanks for taking the time to look at this Roy. I've updated the code HERE.
