Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Separate drawing of a layout
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Separate drawing of a layout (Read 1826 times)
huan_khu
Guest
on:
November 21, 2016, 10:20:11 AM »
Normally, I receive many autocad drawing from a subcontractor. But he put all drawings on a layout with the specific title block. I want to separate those drawings to the single drawing and make a sheet set manager. Could you please show me any LISP to separate multiple drawings on a layout with a fixed title block to a single drawing on a layout? Thank you so much for your help.
Logged
Global Moderator
Seagull
Re: Separate drawing of a layout
Reply #1 on:
November 21, 2016, 10:48:49 AM »
Search this site, I remember some that exported the Layouts but not sure if the associated model space objects were included in the export.
Logged
huan_khu
Guest
Reply #2 on:
November 22, 2016, 03:41:28 AM »
Thank you for your prompt response. BUt I attached wrong drawing. they put all drawing on a layout. Pls refer new attachment. Thank you
Logged
Matt__W
Seagull
I like my water diluted.
Reply #3 on:
November 22, 2016, 06:44:45 AM »
AutoCAD has a command called
EXPORTLAYOUT
Logged
Autodesk Expert Elite
Owner/FAA sUAS Pilot @
http://skyviz.io
Global Moderator
Seagull
Reply #4 on:
November 22, 2016, 10:26:25 AM »
Thanks Matt, looks like that command originated in version 2016.
Was it available in earlier versions?
Logged
GHarvey
Mosquito
Reply #5 on:
November 22, 2016, 11:06:10 AM »
I can confirm that EXPORTLAYOUT exist as far back as release 2013, at least.
Logged
huan_khu
Guest
Reply #6 on:
November 22, 2016, 11:08:30 AM »
Quote from: Matt__W on November 22, 2016, 06:44:45 AM
EXPORTLAYOUT
This command may not fit my problem. I would like to to
separate multiple drawings on a layout with a title block to a single drawing on a layout
. Thanks
I mean we can have a LISP when it runs it will ask 2 points of opposite corners (in this case is a title block). It will find the remained others 2 points of opposite corners. After that it will separate each title block to a drawing on layouts. Thank you very much.
Logged
huan_khu
Guest
Reply #7 on:
February 21, 2017, 10:29:36 PM »
Could anyone help me in this case? Thank you so much
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
