Author Topic: Easily convert ESRI SHP to CSV?  (Read 3602 times)
ChrisCarlson
« on: November 08, 2016, 02:11:48 PM »
Is there a non $2,500 USD method for converting or exporting the values from an ESRI shapefile to a CSV format?
Matt__W
  • I like my water diluted.
Autodesk Expert Elite
ChrisCarlson
Re: Easily convert ESRI SHP to CSV?
« Reply #2 on: November 09, 2016, 07:47:12 AM »
Just downloaded a trial of AutoCAD MAP, need to find out what this data actually contains.
sljohnson
« Reply #3 on: November 09, 2016, 09:23:19 AM »
I've spend some time this week tinkering about with qgis ( http://qgis.org/en/site/ ) to get information out of GDB file package we received. Infraworks was too much of bag of frustration to muddle with for billable work. I'll use the data set this winter to learn and fill in that knowledge hole.
huiz
  • Certified Prof C3D
« Reply #4 on: November 10, 2016, 02:01:45 AM »
If you only need to read the data, you can open the db file in Excel.
ChrisCarlson
« Reply #5 on: November 10, 2016, 08:37:49 AM »
Unfortunately, I'm pulling the coordinates of points and the attached data, opening the .dbf file only returns the value of the attached data.
Looking like my best bet is to import the SHP file into Google Earth and then export the data as a KML.
Willie
  • Going nowhere slowly
« Reply #6 on: November 11, 2016, 03:55:05 AM »
Hi
There is nothing attached.
I assume you just have AutoCAD and not Civil 3D?
Is it a point shapefile?
Are the coordinates projected or geographic?
If it is a point shapefile, It is easy with QGIS.
1. Load the data in QGIS;
2. Open the field calculator;
3. Create a new field;
4.  Under geometry, there are a $X and $Y;
5.  You should get the coordinates, in the DBF file.
Attach the data, and I will have a look at it.
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
ChrisCarlson
« Reply #7 on: November 15, 2016, 08:00:43 AM »
I was able to import into google earth and then save as a KML file. Now the fun part of handling this large quantity of data, currently attempting to filter through 14.3mil lines of XML...awesome.
