Run MESHSMOOTH command on selection set that consist of 3DFACES and POINTS - you may use triangulation for quick setup...
Then first warning dialog box will appear - choose to create MESH and check box to always apply this option when converting non-primitive solids to meshes...
Then second dialog box will appear stating that some entities can't be converted (your selected POINTS)... Also check box that skip this warning and click OK...
Finally gather new selection set :
(setq ss (ssget "_:L"))
And according to my investigations - this won't work with "ss" : (command "_.MESHSMOOTH" ss ""); instead you must use :
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "_.MESHSMOOTH\n!ss\n\n")
Warning!!! : Do not try this if you don't want to perform actions automatically without showing warning dialog boxes... I don't know how to turn them on back after I applied check button to always apply action and skip pop ups...[EDIT] Found and answer to warning message here :
https://www.theswamp.org/index.php?topic=52592.msg575026#msg575026 [/EDIT]
