Author Topic: QLEADER to MLEADER  (Read 4188 times)
jmyrwen
QLEADER to MLEADER
« on: October 16, 2016, 12:33:04 AM »
Hi all, i have code attached. Im just wondering if it could be done in the same way but instead of "QLEADER" it will be "MLEADER"? I already tried changing the command to mleader but doesn't work the same. Thank you in advance. Cheers!
(setq l_ang 90)
(defun c:q (/ sty nm p1 p2 ateblk p3)
(command "cmdecho" "0")
(setq osm (getvar "osmode"))
(setq ort (getvar "orthomode"))
;(command "osmode" "2")
(setq p1 (getpoint "\nPick origin point"))
(command "osmode" "0")
(command "orthomode" "0")
(setq p2 (getpoint "\nPick target" p1))
(if (< (car p1) (car p2))
(if (< (cadr p1) (cadr p2))
(setq p3d (- (cadr p1) (cadr p2)))
(if (< (cadr p2) (cadr p1))
(setq p3d (- (cadr p2) (cadr p1)))
(setq p3 (polar p2 (+ 0.0 (dtr (- l_ang))) (* p3d 1.0)))
(command "QLEADER" p2 p3 p1 "" "" "n")
(setq p3 (polar p2 (+ 0.0 (dtr l_ang)) (* p3d 1.0)))
(if (< (car p2) (car p1))
(command "Qleader" p2 p3 p1 "" "" "n")
(command "osmode" osm)
(command "orthomode" ort)
(defun dtr (a)
(* pi (/ a 180.0))
ChrisCarlson
Re: QLEADER to MLEADER
« Reply #1 on: October 17, 2016, 07:45:41 AM »
Just quickly looking at this line
  1. (command "Qleader" p2 p3 p1 "" "" "n")
an mleader has a different format.
  1. (command "mleader" p1 p2)
This routine doesn't really do anything beyond a standard function. What is the intention?
jmyrwen
« Reply #2 on: October 19, 2016, 01:29:34 AM »
hi, thanks for the response appreciate that, if its not possible on above code i would like the user to input their desired landing gap,(like from one point to another) not a fix distance.
ifncdylan
« Reply #3 on: October 19, 2016, 02:38:10 AM »
If you're going to use command calls to do this, then you'll just need to use the correct syntax for the MLEADER command as described above.
Otherwise I'd suggest perhaps using a leader creation utility and create the leaders via lisp instead of command calls, it's a lot faster as well as stable and you could swap out what kind of leader you're making a lot easier. :)
jmyrwen
« Reply #4 on: October 19, 2016, 03:05:45 AM »
yeah i think mleader cant be done in above code so im now wondering if there's any system (or lisp maybe) that could uncheck landing options
« Last Edit: October 19, 2016, 03:17:37 AM by jmyrwen »
ChrisCarlson
« Reply #5 on: October 19, 2016, 08:54:33 AM »
Landing distance can be set in the style or after creation with
  1. (setq ent (vlax-ename->vla-object (ssname (ssget "_L"))))
  2. (vlax-put-property ent 'LandingGap 0.09375)
ifncdylan
« Reply #6 on: October 19, 2016, 10:33:02 PM »
I figured I could use this kind of function myself, so here is the result I came up with
  1.
  2. (defun C:DrawMLeader ( / points props )
  3.   (setq points ((lambda ( / prmpt a ptlst)
  4.                 (setq prmpt "\nSelect first point..")
  5.                 (setq a nil)
  6.                 (while (if a (setq a (getpoint a prmpt)) (setq a (getpoint prmpt)))
  7.                   (setq ptlst (cons a ptlst))
  8.                   (setq prmpt "\nSelect next point or right-click/space to exit")) ptlst))
  9.         props (list
  10.                         (cons 'LandingGap 1.5)
  11.                         (cons 'ArrowheadSize 2.5)
  12.                         (cons 'TextHeight 2.5)
  13.                         )
  14.         )
  15.   (Make_MLeader points props)
  16.
  17.  )
  18. (defun Make_MLeader (points props / acadObj doc modelSpace mLeaderProps mLeader)
  19.     (setq acadObj (vlax-get-acad-object)
  20.           doc (vla-get-ActiveDocument acadObj)
  21.           modelSpace (vla-get-ModelSpace doc)
  22.           points (vlax-points->safearray points)
  23.           mLeader (vla-AddMLeader modelSpace points 0)
  24.           )
  25.   (cond (mLeader
  26.     (mapcar '(lambda (a) (if (vlax-property-available-p mLeader (car a)) (vlax-put-property mLeader (car a) (cdr a)))
  27.                )
  28.                 props
  29.     )
  30.     mLeader
  31.    )
  32.    (T nil)
  33.    )
  34. )
  35. (defun vlax-points->safearray ( l / out)
  36.   (setq in (flatlist l)
  37.         out (vlax-make-safearray vlax-vbDouble (cons 0 (- (length in) 1)))
  38.         out (vlax-safearray-fill out in)
  39.   )
  40. )
  41. (defun flatlist (l)
  42.         (cond
  43.         ((null l) nil)
  44.         ((atom l) (list l))
  45.         ((atom (car l)) (cons (car l) (flatlist (cdr l))))
  46.         ((append (flatlist (car l)) (flatlist (cdr l))))
  47. )
  48. )
  49.
You can make your point selections in your usual manner, and then just pass a list of points and properties to the command and it will create the MLeader for you using visual lisp and apply those properties to the leader.
« Last Edit: October 19, 2016, 10:45:18 PM by ifncdylan »
jmyrwen
« Reply #7 on: October 20, 2016, 12:25:40 AM »
Hi thank you very much for the efforts, i tried your code but for some reasons nothing happen  :thinking:
jmyrwen
« Reply #8 on: October 20, 2016, 12:27:03 AM »
i am new to lisp and i dont know where or how to use it :( Thanks anyway.
ifncdylan
« Reply #9 on: October 20, 2016, 12:45:37 AM »
You might need to install the visual lisp extensions? They aren't distributed with AutoCAD anymore.
As far as using the code goes, once you've got the extensions installed and the functions loaded in your file, instead of:
  1. (command "mleader" pt1 pt2 pt3)
You would use the custom command giving it the list of points and any properties you want (e.g. the landing gap):
  1. (Make_MLeader (list pt1 pt2 pt3) (list '(LandingGap . 1.5)))
That code will also require the visual lisp extensions if you haven't installed them; either way, that could would set the landing gap of the last inserted object (presumably the MLeader you just created). Be careful though, as if the last object you doesn't have the LandingGap property then it will produce an error.
jmyrwen
« Reply #10 on: October 20, 2016, 02:22:03 AM »
this is what i did, i load it and invok the command but nothing happens< i didnt get the visual lisp extension
ifncdylan
« Reply #11 on: October 20, 2016, 05:57:03 AM »
Nothing which uses a visual lisp command will work without installing the extension, which you can get from the autocad site under your specific product :)
roy_043
  • BricsCAD 18
« Reply #12 on: October 20, 2016, 08:07:36 AM »
@jmyrwen:
I have a hunch that you are not testing the actual command in ifncdylan's code. The command is called DrawMLeader.
jmyrwen
« Reply #13 on: October 20, 2016, 01:54:31 PM »
@jmyrwen:
i know the command, did you try it your own?
roy_043
  • BricsCAD 18
« Reply #14 on: October 20, 2016, 02:08:20 PM »
@jmyrwen:
Yup. Works OK. Note: I use BricsCAD.
