Author Topic: Issues compiling to VLX  (Read 5956 times)
squirreldip
« on: October 14, 2016, 01:58:16 PM »
I have a .cmd script which creates a .lsp file to write .dcl files by reading a folder containing source .dcl files.  I'm getting an error when using VLIDE to create a vlx from the .lsp :
; error: too many arguments: (PROGN (SETQ OUTFILE ( ... )) (PRINC "DUALCAR : dialog {\n" OUTFILE) (PRINC "                   label = \"RFL Dual Carriageway 3DPoly Creator\";\n" OUTFILE) ... )
The .lsp loads fine and executes correctly.
If anyone has any ideas it would be greatly appreciated.
squirreldip
Re: Issues compiling to VLX
« Reply #1 on: October 14, 2016, 02:02:15 PM »
Is there a limit to how many lines can be contained within a (progn) block?
Edit:
Answer is yes (here)
« Last Edit: October 14, 2016, 02:05:42 PM by squirreldip »
MeasureUp
« Reply #2 on: October 16, 2016, 07:08:31 PM »
I did not look your attached code. But can you replace the portion (princ "label = \"RFL…) with this:
(princ (strcat "label = \"RFL Dual Carriageway 3DPoly Creator\""
       "\n"
       OUTFILE
       ); end of strcat
Note: take care of using ";" in a single line because ";" breaks the rest in the line.
Then you may be able to fix (princ "DUALCAR : dialog {\n" OUTFILE).
Please also have a look "strcat" function in help.
HTH
squirreldip
« Reply #3 on: November 22, 2016, 11:41:29 AM »
Thanks MeasureUp - the suggestion should work.
I think the big issue for me was just not realizing that there is a limit.  I solved my problem by temporarily storing a list then iterating through that list.  Yours is probably better as no variable needs to be stored.
roy_043
  • BricsCAD 18
« Reply #4 on: November 22, 2016, 01:51:18 PM »
Grrr1337
« Reply #5 on: November 23, 2016, 07:22:37 AM »
See: https://www.theswamp.org/index.php?topic=48883.0
I've never attempted to compile to VLX, but after reading this I thought would (repeat 1) can be an alternative of a loooong (progn).
(apply ''((a b c)(a b c))
vevo.bg
ribarm
  • Marko Ribar, architect
« Reply #6 on: November 23, 2016, 08:02:52 AM »
I was about to ask does anyone know limit of (setq var1 value1 var2 value2 ... )? I know this can be simplified by separating setq-es, but just for an info...
M.R. on Youtube
ChrisCarlson
« Reply #7 on: November 23, 2016, 12:56:21 PM »
Could the length of a progn issue be eliminated by creating a sub-function and simply calling it?
« Reply #8 on: November 23, 2016, 01:20:00 PM »
IMO, if you start to run up against the argument limits inherent in AutoLISP, you really need to take a step back and restructure your program; in the hundreds of thousands of lines of code I've written, I've never been troubled by the maximum number of arguments afforded by functions such as progn, cond etc.
Grrr1337
« Reply #9 on: November 23, 2016, 01:48:00 PM »
Thats what"the List Manipulator" said.  :wink:
vevo.bg
ur_naz
  • Made in Ukraine
« Reply #10 on: November 24, 2016, 05:52:23 PM »
You can add DCL to your VLX app. Making DCL on the fly is very bad idea.  :uglystupid2:
« Reply #11 on: November 24, 2016, 06:35:43 PM »
DCL as part of a VLX application is still unencrypted and merely appended as plain text to the VLX file.
« Reply #12 on: November 24, 2016, 08:35:11 PM »
Support this assertion please.
ribarm
« Reply #13 on: November 25, 2016, 04:11:32 PM »
I've successfully loaded lisp with 10MB size, containing 1000000 variables setq-ed in one line... So if I may conclude (setq) has no such issues with limitations... Note that in lisp that I used to create lisp (10MB) (load) function isn't quite thankful for checking... So as soon as first loop was over I terminated CAD and started it again when I used copy+paste method with lisp (10MB) into CAD interface for loading that setq... It was success and I still had to wait for loading 10MB lisp for a while... Here is my (c:testsetq) for creation of ttt.lsp (10MB), so that you can experiment on your own if you want, but I warn you if you have more important thing to do, please ignore this test...
(defun c:testsetq ( / f )
  (setq k 1000000)
  (while t
    (setq f (open "c:/SHARED FOLDER/ttt.lsp" "w"))
    (write-line "(eval (setq" f)
    (repeat (setq k (+ k 1000000))
      (write-line "a 1" f)
    (write-line "))" f)
    (close f)
    (load "c:/SHARED FOLDER/ttt.lsp")
P.S. "k" variable is global in order to be checked upon load failure (but this won't happen at least according to my testings)...
M.R. on Youtube
ur_naz
  • Made in Ukraine
« Reply #14 on: November 25, 2016, 04:54:18 PM »
Ok, if you write dynamic DCL you have to
1) Write more code and read much longer bumf;
2) Check  more errors and every slash around strings;
3) Check if DCL is created/exist/loaded. Some paranoiac antivirus software and latest versions of windows can prevent file I/O operations.
4) Rewrite your code every time then Autodesk fails with codepages...
« Last Edit: November 25, 2016, 04:57:59 PM by ur_naz »
