Author Topic: Civil3D - ssget  (Read 2524 times)
MSTG007
Civil3D - ssget
« on: October 12, 2016, 08:36:36 AM »
Looking for some Civil3D Object Names to place into a ssget for the following:
-Structure Labels
-Pipe Labels
-Pipes
-Structures
-Surface
-Contour Labels
I was using the following code to dump the data but having a hard time finding the right object name.
(vlax-dump-object (vlax-ename->vla-object (car (entsel))) t)
(ssget "x" '((0 . "Object")))
Thanks for the help again.
Civil3D 2020
Re: Civil3D - ssget
« Reply #1 on: October 12, 2016, 10:10:04 AM »
Use the LIST command to get the name:
Command: LI LIST 1 found
                  AECC_PIPE  Layer: "C-STRM-PLAN"
                            Space: Model space
                    Material: Sitework.Planting.Gravel.Crushed
                   Handle = 1679
              Type : AeccDbPipe
