Dear Marc'Antonio Alessi,
Thank you so much for your time and efforts!
I am really very sorry to say that I am not able to use these codes. I am comparatively very new in AutoLisp/Scripting world!
How to use these codes actually? I meant the methodology to use these codes.
I copied these codes to a text file.... then changed the extension of the .txt as .lsp... loaded the file in AutoCAD using APPLOAD. But I did not find any command to invoke these codes. I tried- i) "ALE_Utl_PurgeGroupsNoName" to invoke one .lsp; and ii) "ALE_DeleteGroups" to invoke another .lsp . But it did not work. I know, this is not the way. I searched, but did not able to find the methodology.
Should I copy these codes to ACADDOC.lsp and then invoke the command ? What is the command actually then?
Or Should I change these codes to [e.g...(defun c:abc()...] type, so that I can invoke the command as 'abc' in command line? If so, how to integrate your codes to [...(defun c:abc()...] format?
Please help! You may also share some links, where these methodologies are described.
Thank you.
Bests,
Ranjan
