Author Topic: debug C# on MAP 2015 [SOLVED]  (Read 3398 times)
didier
  • expatrié
« on: September 26, 2016, 03:08:56 PM »
Hello !
I am beginner in visual studio community and C# and I have a problem with debug
does anyone know how to debug a code C# working on MAP 2015 ?
gile (which is French also but good programmer) explains to me but his explanations work only on AutoCAD, with MAP it does not work
Windows 8 and MAP 3D 2015.
thank you
« Last Edit: September 29, 2016, 10:50:44 AM by didier »
eternal beginner ...
my english is not fluent ...
Re: debug C# on MAP 2015
« Reply #1 on: September 26, 2016, 07:56:23 PM »
The same steps that gile gave you for Autocad should still work with Map. I followed the Autocad instructions in order to debug Civil 3D, which is built on top of Map. What problems, errors, are you getting?
didier
  • expatrié
« Reply #2 on: September 27, 2016, 03:48:09 AM »
Bonjour, Hello
I make exactly what gile recommend
I put the path of the EXE in the "start program"
I Build the solution whitout error
When I start (F5) Autocad makes an error message and stops
https://dl.dropboxusercontent.com/u/91165581/erreur_visual_studio.avi
some ideas ?
thank you.
didier
  • expatrié
« Reply #3 on: September 27, 2016, 03:54:17 AM »
oops !
I forgot the end of the message in Visual Studio which I do not understand but maybe that you understand it :
The program '[9580] acad.exe: Managed (v4.0.30319)' has exited with code -529697949 (0xe06d7363) 'Microsoft C++ Exception'.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #4 on: September 27, 2016, 03:56:06 AM »
I saw some references to the GAC there .... are you using the COM interface ??
Can you take a snapshotof the references you are using ?
I can't actually see the error message  ... can you post it please.
Because it looks like a small project, it may help if you zip the complete solution and post it here.
... that may save some guessing games.
Called Kerry in my other life
I live at UTC + 13.00
didier
  • expatrié
« Reply #5 on: September 27, 2016, 05:02:56 AM »
Bonjour
I saw some references to the GAC there  I do not know what that is
are you using the COM interface ?? I do not know how to answer
I can't actually see the error message  ... can you post it please. Which message I have to post ?
The zip file is joined to the message, it is a very (very, very) simple project, I am beginner don't forget.
thank you for your interest.
gile
  • Marseille, France
« Reply #6 on: September 27, 2016, 07:36:58 AM »
The solution is OK, I just needed to reset the AutoCAD references to match my computer organisation and all worked fine.
The problem seems to be related to AutoCAD MAP (possibly 2015) and/or Windows 8.
Sorry, I cannot help further, I do not have AutoCAD MAP, neither Windows 8.
gile
  • Marseille, France
« Reply #7 on: September 27, 2016, 09:26:49 AM »
For those whom enconter the same problem, it seems to be a known issue related to AutoCAD MAP with Windows 8, 8.1 and 10 and Autodesk purposed a workaround see this topic.
didier
  • expatrié
« Reply #8 on: September 27, 2016, 11:30:53 AM »
Coucou, Hello
I have already thanked Gilles on the French site where we discuss
actually yes! there is a French site (hihi)
http://cadxp.com/topic/43515-debug/page__pid__249433__st__20#entry249433debug/page__pid__249433__st__20#entry249433
I thank you also for trying to help me.
This happen only with localized versions of AutoCAD Map 3D
I do not have more than to persevere
Thank you
« Last Edit: September 27, 2016, 11:36:13 AM by didier »
