Author Topic: Wipeout ins't hide  (Read 3563 times)
Fabricio28
Wipeout ins't hide
« on: September 22, 2016, 08:21:47 AM »
Hi guys,
How are you.
I couldn't hide the layer -MALHA with wipeout command.
I don't know what's wrong.
Anybody could help me out, please!
I'm attaching the pdf and dwg file.
Rob...
Re: Wipeout ins't hide
« Reply #1 on: September 22, 2016, 08:30:15 AM »
Display order - send to back
CAD Tech
Fabricio28
« Reply #2 on: September 22, 2016, 08:36:31 AM »
Isn't working for me...
When I print the file that crazy line shows up.
Rob...
« Reply #3 on: September 22, 2016, 08:57:29 AM »
That's why I don't use wipeouts.
CAD Tech
Fabricio28
« Reply #4 on: September 22, 2016, 09:27:36 AM »
Wipeouts are not good.
I've created but isn't working properly.
Rob...
« Reply #5 on: September 22, 2016, 09:29:52 AM »
IMHO, they have always yielded inconsistent results.
CAD Tech
ChrisCarlson
« Reply #6 on: September 22, 2016, 09:44:23 AM »
Try using a solid hatch set to print to 255,255,255.
Only items behind the wipeout are hidden, by sending the wipeout to the back nothing is hidden.
Rob...
« Reply #7 on: September 22, 2016, 09:45:45 AM »
Don't send the wipeout to the back. Send the items you want to hide to the back. (I thought that was clear.)
« Last Edit: September 22, 2016, 10:09:42 AM by Rob... »
CAD Tech
Fabricio28
« Reply #8 on: September 22, 2016, 10:01:00 AM »
Don't wend the wipeout to the back. Send the items you want to hide to the back. (I thought that was clear.)
I don't understand why only one rectangle worked fine.
Fabricio28
« Reply #9 on: September 22, 2016, 10:03:56 AM »
Hi Master_Shake
Isn't working too..
Rob...
« Reply #10 on: September 22, 2016, 10:10:49 AM »
One more try. Send the objects on layer -MALHA to the back. That should be clear now.
CAD Tech
ChrisCarlson
« Reply #11 on: September 22, 2016, 10:14:05 AM »
Check your layer settings for VIEWPORT
:hint: it's on a non-plottable layer
Also why do you have wipeouts on top of wipeouts?
Rob...
« Reply #12 on: September 22, 2016, 10:19:47 AM »
Yeah, good catch. The wipeout won't hide anything during printing if it is set to not plot. I totally missed that.
« Last Edit: September 22, 2016, 10:35:34 AM by Rob... »
CAD Tech
Fabricio28
« Reply #13 on: September 22, 2016, 10:33:23 AM »
Thank you!!!!!!!
Very happy :)
and:
Command: WIPEOUT
Specify first point or [Frames/Polyline] <Polyline>: F
Enter mode [ON/OFF/Display but not plot] <ON>: D
Thanks perfect
Fabricio28
« Reply #14 on: September 22, 2016, 10:33:47 AM »
Yeah, good catch the wipeout won't hide anything during printing if it is set to not plot. I totally missed that.
Thank you too Rob.
Regards
