Thank you Master Shake, I could tell them that. BUT I would want to check it first before i even say "check your domain permissions again"
Before what i said was [ quote From our friend BlackBox ]
"Once a DST (sheet set file )has been created within any given project on the server's share, the parent folder's NTFS / Share permissions should be inherited. Meaning, your project folders likely inherit permissions set for the share itself, so any 'domain user' or other applicable 'user group' has X, Y, Z permissions for that folder and any files within.
In the same dialog, under 'Permission entries', you should see yourself with 'Full Control' presumably (as the Creator/Owner, listed as 'Parent Object'?), and something along the lines of 'Domain Users' also presumably with 'Full Control' but this *should* be inherited from some folder within the network drive's letter (i.e., Z:\Projects\, etc.).
I set our server's Share permissions to 'share all', and then use NTFS permissions to manage who within our domain has access to what files, and folders using Active Directory."
They said we did all that.
Thank you in advance
